G35 belt squeaking/alternator question
Old Aug 21, 2023 | 12:41 PM
dennisknightdog's Avatar
grey
Red face G35 belt squeaking/alternator question
I have been trying to stop a squeak coming from the front of the car for the last few months. I have tightened, used belt conditioner, and then replaced the belts for both sides ( alternator and AC ).
Yesterday I was under it replacing the belt on the alternator side again and noticed a bunch of fine belt pieces on the front of the alternator. The belt had been worn down to the cloth strands in the groves. when I started the car it squeaked again so I shut it off and got back under the car. the car had not been ran so everything was cold except for the pully on the alternator it was HOT. I had the wife start/stop the car several times and watched to see if the alternator was moving as expected ( and no squeaking this time) it was and after the 2nd start the pully on the alternator was cold ???????
Is it possible that sometimes the alternator is not spinning when the car is running/started and other times it spins? I took the belt back off and the alternator spun as I would expect it with no real resistance.
Old Aug 26, 2023 | 01:42 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Spin everything by hand and find the bad pulley, if I had to guess you have a tensioner that's failing and putting the belt out of alignment which is causing it to fray.
Old Aug 28, 2023 | 03:27 PM
grey
thanks @cleric670 i ended up replacing both pulleys and that helped a little bit. The squeaking now only happens when the car first starts up and when the AC is on. So now I will slowly tighten the belt.
I hope this fixes the problem.
pizzaboydanny
Jan 16, 2017 10:09 AM
Smitty50
Dec 27, 2013 01:47 PM
equilibrium
Jul 7, 2011 08:47 AM
G35_916
V36 Engine, Exhaust, Drivetrain & FI
21
Dec 30, 2010 12:23 PM
CleanGThree5
Dec 29, 2006 03:41 PM
