Will the Z tube benifit my 05 298HP G
Old Mar 24, 2005 | 07:06 AM
byeZhiG's Avatar
Will the Z tube benifit my 05 298HP G like the previous models?
Old Mar 24, 2005 | 08:05 AM
neffster's Avatar
Yes it will. I've installed one in g8tor20's 2005 G35 coupe and it fit just fine.
Old Mar 24, 2005 | 09:51 AM
roneski's Avatar
Devil's Advocate
Can't hurt. Just make sure that it doesn't rub against any AC lines. It normally won't in the '03-'04s, but I haven't seen one in an '05 yet. I'f Neff says it'll fit I'm sure it'll be fine though.
Old Mar 24, 2005 | 10:12 AM
caelric's Avatar
My theory is that the only difference between the 2005 350Z Anniversery/Track 300 HP engine and our 2005 G35 6MT Coupe engine is the resonator in the air tube.
So, replacing the resonator with the Z-tube should make it a nice, even 2 HP. Which no one will be able to feel any difference, and even an engine dyno might have trouble noticing and discerning the difference.
Dave
Old Mar 24, 2005 | 11:21 AM
silver04's Avatar
"G" Spot
It will give you exaclty 1.9 hp....so you can't get 300 hp.
Just kidding..Although they don't give you large gains, the z-tube will help the engine breath a little better. Like caelric said..the resonator can free up some hp due to a better flow of air from the z-tube.
Old Mar 24, 2005 | 11:30 AM
JKashat's Avatar
Anyone know where the best deal to get one is? I am interested in the Z Tube for my girlfriends '05 Laser Red (5AT) Loaded Coupe along with the JWT Pop Charger from my old '03 Brilliant Silver (5AT). I have heard that this is a good/popular combination, any thoughts? I will also be putting installing my NISMO Weldina exhaust system on her car, even though she doesn't want it, since it didn't sell on eBay. Thanks.
Old Mar 24, 2005 | 12:16 PM
byeZhiG's Avatar
thanks
sounds like I will get the z tube, anyone tried the crawford plenum on an 05 6-speed or do I need to be a pioneer?
Old Mar 24, 2005 | 12:40 PM
mastermind050's Avatar
I just put the Z Tube on my 05, and it made it sound a lot nicer. Quick blips of the throttle sound much meaner, and the sound from the engine is slightly louder with the tube at higher RPM's. Now don't expect it to be super loud and deep as if you were adding a full aftermarket intake. It still has a stock sound, just a little throatier and a bit louder, but not much.
As far as power gains go, nothing noticable, probably more in your head than anything, or maybe just all in mine...
Old Mar 24, 2005 | 12:55 PM
PhxBlue's Avatar
Polyester Pileup FTW!
Sorry bro I have covered that ground already.
Old Mar 24, 2005 | 04:59 PM
caelric's Avatar
I have one in my garage, waiting for this weekend to do the install. I'll let you know how it goes.
Dave
Old Mar 24, 2005 | 05:17 PM
pepe224's Avatar
it wont give you as much as you want like in the 04 but it should give you a little more
Old Mar 26, 2005 | 08:44 PM
caelric's Avatar
Easy install on the Crawford Plenum, much easier than the Stillen Engine Damper Brace that I did at the same time, better instructions, as well.
I think the plenum really helped the high end, and maybe some bottom end as well. Definitely worth it.
Dave
Old Mar 27, 2005 | 07:52 AM
neffster's Avatar
Probably Grubbs or Performance Nissan. If I lived in Michigan I'd run the z-tube and P/C without a doubt.
Old Mar 27, 2005 | 08:08 AM
JKashat's Avatar
Thanks Neffster!
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
