VQ35de Power
Old Mar 30, 2005 | 01:42 PM
ZeroGen's Avatar
Omega Enthusiast
Originally Posted by OldVFRGuy
This is one of our club members car specs.....his car runs STRONG.
He has one of the highest N/A that I have seen.
RugRatCoupe/Performance Mods
Polished CRAWFORD"Z"Plenum, R.T.Cats, NISMO Flywheel, NISMO Perf.Clutch, NISMO P.Plate, STILLEN Exhaust w/X-Pipe, INJEN Polished CAI, HYPER GROUND Wires, EIBACH PRO-KIT, NISMO SwayBars, JDM NISMO/RAYS/S-Tune 19" LMGT-4's, BRIDGESTONE S-03's. Cut Down Engine Cover, R.E.Short Shifter, PENNZOIL/LUCAS Synth.Oil, Snow/Aqua-Mist Water-Methanol Injection, U.R.Crank Pully, T.S. ECU...
268.3whp/251.6tq. 1/4 13.86@101.38/60' 2.126 all #'s before W/M Inj
What kind of cam is he running? Also, has he considered using ITBs?
I'm thinking ~330 bhp at the crank is feasible with the right mods.
Old Mar 30, 2005 | 03:31 PM
g3po's Avatar
tires
Originally Posted by Deang35c6
My best 60' is 2.0xx on summer tires in 45 degree weather. These cars don't launch very well. 245 width may be too narrow, but due to VDC and most people runnin the 245/275 option, the 275s may be too wide. I'll find out this spring.
If you want wide street tires witou pissing off the VDC you can run
295/35-18 and 265/35-18. I've been running them for a few k now and all is well. I use SSR Comp-H wheels since they are wide , light and inexpensive.
It's supriseing how this much rubber tuck into the fender well, they don't bug out at all.
Old Mar 31, 2005 | 03:35 AM
deadmanincbh's Avatar
Well then I stand corrected and I thank you people for clearing thing up. But I was making and assumption based on what have seen many manual Z owners claim they are getting stock or with at least an intake and/or exuast.
Old Apr 3, 2005 | 09:58 AM
Wingsprint's Avatar
Talking Weight and Gears!!!!!!!!!!
Well, there is this 3.9 gear that when combined with the TS ECU for higher redline that has done wonders for some Z owners.
The G35 is not a good choice if you are looking to drag race.
If you are not going to add F.I. forget trying to squeeze more power out of the VQ- The ROI (return on investment), is crappy.
The best way to lower times at the strip would be to remove weight and change the gears! You could put $10,000 in the VQ and still get smoked by a stock G35 with a 200lbs. weight reduction and gear change from stock to a more aggressive rear end ratio.
Old Apr 5, 2005 | 01:05 AM
ZGUY52's Avatar
I have read in mags and on this site that the stock rods are only good for 400BHP. The 2005 had "internal strengthing of the motor", so the 2005 may be stonger. Of course you can replace the rods but tearing down an engine gets expensive. Someone posted onetime about putting the old Skyline turbo motor in a G. The old skyline turbo was like the Supra turbo and could go 700+bhp. I would be intereted in that info if anyone has it.
Old Apr 5, 2005 | 06:52 AM
KPierson's Avatar
The general consensus is that it would be cheaper to rebuild the VQ then to try and fit an RB in the car. The VQ has more displacement, so when built should be able to produce more power.
Tmatheso
Dec 13, 2015 03:24 PM
mbe32
Nov 13, 2015 11:09 PM
vamarris
Sep 26, 2015 12:56 PM
