REAL VDC mod, perhaps???
Old Apr 27, 2005 | 12:41 AM
cungkpham's Avatar
I was kinda thinking for quicker VDC on/off switch for the MT...
MAYBE...
you know how for Reverse gear, you need to press down on the **** and then move over to "R"?...
Well... have a contact switch on the shifter housing for "VDC off" when the contacts meet... and then "VDC on" when you press the **** down again...
Bad part is that whenever you go in reverse, you turn VDC "OFF"...
am i making sense?
Old Apr 27, 2005 | 01:48 AM
DirtyMechanic's Avatar
hey why dont u take that VDC switch out and see how many wires are going to it. your idea has a few flaws i.e. not a simple on/off switch
Old Apr 27, 2005 | 09:45 AM
Brando's Avatar
Yeah....I just want to move mine over to the console right by the seat heater switches.
Should be pretty easy to just extend the wires.
Old Apr 27, 2005 | 09:47 AM
ainsley's Avatar
Sounds complex. I think I'd stick with KP Technologies' offering.
Old Apr 27, 2005 | 09:50 AM
Brando's Avatar
Personally, I'd rather turn if off when I want .....rather than having to always remember to turn it on in the rain and wet.
Old Apr 27, 2005 | 03:17 PM
SFLG35's Avatar
FGC President
with the kptech vdc mod you can turn it off and on whenever you want.
if you would rather turn it off when you want then that is the way it works from the factory.
you could extend it but you would still need to use the same type of switch that the factory one is.
Old Apr 27, 2005 | 05:53 PM
G35_coupe_6MT's Avatar
I rather press the button myself than pay 39$ for it.
Old Apr 27, 2005 | 06:20 PM
NUTS01808's Avatar
^ so true...whats wrong with reaching over and hitting a button...unless your belly is in the way...J/K
Old Apr 27, 2005 | 07:12 PM
Dizz's Avatar
Thanks Clint...
Old Apr 27, 2005 | 08:22 PM
Sickone's Avatar
actually the VDC switch is pretty simple.
There are 4 wires
2 wires are for the light in it
2 are for the VDC on/off - one is ground. It is a simple momentary to ground.
So to move it really only requires one lead + ground (assuming you don't need the light)
Old Apr 28, 2005 | 07:24 AM
Brando's Avatar
Thumbs up
Originally Posted by Dizz
Thanks Clint...
That's exactly what I want to do!
That is where is should have been in the first place.
Thanks!
Old Apr 28, 2005 | 09:04 AM
z_with_back_seat's Avatar
It is as easy as that, 4 wires to extend. I did the same mod a long time ago. I do not know about the '05 but the '03 & '04 have a spot that is easy to cut from the center council. It was like it was designed to fit there. You can order a blank to fit in where you took the VDC button.
Old Apr 28, 2005 | 03:49 PM
Texasscout's Avatar
The reason they "hide" the switch is, thay don't WANT you to turn it off! If Infiniti had there way, you couldn't turn it off.
Old Apr 29, 2005 | 10:59 AM
madchef's Avatar
Yeah, it's a saftey feature, and they wouldn't want you accidently turning it off while looing for the heated seat switch
g.spot
May 9, 2016 10:54 PM
MThawkins86
Oct 24, 2015 02:07 AM
INVADER_6MT
Sep 3, 2015 01:47 AM
