HEHP: engine service light went on.
Old May 10, 2005 | 09:33 PM
Ts916G35's Avatar
All i got on my 04 Sedan is the K&N Filter and the custom Midpipe .
Why whould my engine service went on?i diconnect the bettery and wait for 5 mins and connect it back. the light was gone.
so, should i go back to Dealer for them to check out?
would my only 2 mod avoid my warrenty?
would they charge me for checking?
thanks for HELP.
Old May 10, 2005 | 09:44 PM
realdieu's Avatar
Your CEL should not trigger by the installation of a filter and midpipe. UNLESS, you improperly installed it or you damaged the MAF. By resetting the ECU, it will take a short while for the CEL to reappear. It could be one block or fifty miles. By the way, you did not oil the inside of the filter did you?
thanks for HELP.
Old May 10, 2005 | 09:45 PM
ChazM's Avatar
you can't go to the dealer because you know the CEL is due to the new mod, unless it was a major coincidence....which i doubt.
Old May 11, 2005 | 12:16 AM
Gman2004's Avatar
go to a performance shop and have them read which code you are throwing with a obd II. This will tell you what is wrong with the car. If it is something major then you strip the mods of the car and go to the dealer. I doubt is anything major. The cel lights usually have to do with emissions.
Old May 11, 2005 | 05:21 AM
Ts916G35's Avatar
i didn't not oil the filter...
why?
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
derres
Aug 28, 2015 03:27 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
