Finally got video clip of my exhaust setup...
Old Jun 20, 2005 | 09:18 PM
G35Wizard's Avatar
I finally got a night video of my exhaust...cant really hear the rasp to much, but I can, since I was sitting in the drivers seat..but here is the link to the vid..
Old Jan 5, 2006 | 02:44 AM
NETSHARK's Avatar
wanna go same setup as yours but am gonna order the fuji later, just ordered megan resonated test pipes.
btw no chance to hear the clip again ?
Old Jan 5, 2006 | 06:56 PM
SI_G35Coupe's Avatar
NETSHARK, i doubt you will get this clip again b/c Wizard sold his Fujitsubo Exhaust... to ME!
you can click this link to hear clips of my current setup
(Z-tube, Popcharger, MD 3/8" plenum spacer, TopSpeed Pro1 headers, Crawford Cats, Fuijitsubo Y-pipe, and Fujitsubo Legalis-R exhaust)
Old Jan 5, 2006 | 10:26 PM
Mr_pharmD's Avatar
was there any rasp with that setup? Also, did u ever have a check engine lite on?
Old Jan 6, 2006 | 03:30 AM
rasp, i don't think so. but that's a tough question to answer since "rasp" is pretty subjective to the listener.
as for the CEL... well my car is currently throwing a hard CEL code for the Primary O2 sensor (hard code meaning it cannot be reset, you actually have to remedy the cause to remove it). i do not believe this to be at all related to the cats or the rest of the exhaust since those components are all downstream of the malfunctioning o2 sensor. i believe it is an issue with my headers (which may be leaking)
Old Jan 6, 2006 | 03:45 AM
Mr_pharmD's Avatar
thats interesting with the cel. I recently installed headers/cat/y pipe and I cant figure why i'm throwing a code.
How can u tell that your headers are leaking?
Old Jan 8, 2006 | 12:03 AM
NETSHARK's Avatar
Thank you SIG35Coupe first i wanna say Congratulations on the Exhaust, i allready downloaded all of your clips :P, i really wanted to hear his clip because of the Resonated Test Pipes, wanted to hear how raspy they would add.
Old Jan 8, 2006 | 03:52 AM
well, for 1 thing since it's an error on the first o2 sensor that is installed in the header outlet pipe, it's gotta be a problem somewhere up there
also i spoke to the guys at MRC and they said aftermarket headers sometimes develop a leak (i think they said at the connection to the block). either way, i know i have an exhaust leak somewhere b/c i can hear it, i just can't pinpoint where it is. alot of people say to run the car and spray some soapy water to show where it's leaking from but i need the car on a lift for that
i've also developed a nasty vibration at around 2200rpms from the driver side header/cat area, so i think something has worked loose slightly and now that whole side is making contact with the body.
cbax
Intake & Exhaust
11
Jul 15, 2023 12:43 AM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
