Brake Booster Cover
Old Jun 13, 2003 | 12:30 AM
myG35ZX's Avatar
Brake Booster Cover
Hey... Who stole my cover. Z's have a cover. Why none for the G?
Robert
G35 Coupe 5AT, DP, Tire and Wheel Pkg., Aluminum Pedals, Clear Corners, missing turbo
Old Jun 13, 2003 | 01:30 AM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Re: Brake Booster Cover
Yeah that sucks, The G is more expensive too. Oh well just go to Nissan and order a cover......
Old Jun 13, 2003 | 05:28 AM
juicedcoupe's Avatar
Don't waste your time. The 350Z cover will NOT fit on the G; I have confirmed this.
Old Jun 13, 2003 | 06:31 AM
This is what I did.
Old Jun 13, 2003 | 08:04 AM
cato's Avatar
SouthernComfort Moderator
What is a Break Booster Cover?
God I love this car!
Old Jun 13, 2003 | 08:52 AM
The brake booster cover in the picture in my previous post is located on the driver's side of the engine bay close to the windshield. It covers the brake booster,brake lines, master cylinder,etc. that are visible on a G35 from the factory. Compare the pic from my earlier post to the attached pic.
Old Jun 13, 2003 | 09:15 AM
myG35ZX's Avatar
Very Nice! Did you use a plastic Sheet (1/8th) and cut to shape? BTW, I like the plenum cover. What type of paint did you use?
Robert
Old Jun 13, 2003 | 12:46 PM
I made a cardboard template and then cut 1/8 inch thick lexan to size. As for the paint, it was a hi-temp spray from Auto Zone; I can't remember the exact brand or color, though.
Old Jun 13, 2003 | 12:59 PM
cato's Avatar
Wow! I really like what you did. How is it attached?
Where can I get lexan? I want to do mine like yours.
Old Jun 13, 2003 | 01:11 PM
On the left side of the cover, it actually fits perfectly within the seals. On the right side of the cover, where there are no seals, I used a small piece of double-sided bodykit tape to secure it.
I imagine a Home Depot or Lowes would have the Lexan. I found a piece in the maintenance department where I work. I used a flat black hi-temp spray paint to finish it off.
Old Jun 13, 2003 | 02:23 PM
nas4a's Avatar
Sheets of Lexan can be bought at Home Depot, near where they sell windows. It varies in thickness, and you can get all different qualities and sizes. It's really tough to cut correctly though, as it's somewhat brittle and prone to cracking if you try and force it.
G35 Coupe, 6MT, DG, Prem.
Old Jun 13, 2003 | 03:12 PM
cato's Avatar
What did you use to cut the lexan?
I have a Dremel tool with cutting heads,
I assume this would do the job.
Old Jun 13, 2003 | 04:48 PM
The guys in our Maintenance shop did the cutting. I will ask them on Monday what they used. The Dremel would probably work, though.
Old Jun 13, 2003 | 04:56 PM
myG35zx,
The paint is Plati-kote Blue Metal Flake 311. It matches very well depending on the lighting as it won't change colors to keep up with the caribbean blue.
Old Jun 13, 2003 | 10:08 PM
Gordgee's Avatar
Administrator
The best thing to cut the lexan with would probably be a band saw if you have access to one. The dremel would do, but a lot more work.
<font color=green>GG</font color=green>
