Remote Start - One Function Remote?
Old Jan 5, 2006 | 03:50 PM
  #31
rupdog326's Avatar
Out of many - one people
Originally Posted by pp7
Hey rupdog326 is there anything specific that I should tell the installer when getting the valet remote starter hooked up to the keyfob. Were there any issues/difficulties when installing and programming it? Is the 3 keylock press combination a standard feature with this kit or was there some other thing to install to make this work? Thanks for any help.
The install was done by an Infiniti dealer and it took @ 15 minutes. I gave no input on the programming of the remote. They kept the valet key - I don't remember the exact reason why.
Old Jan 5, 2006 | 05:07 PM
  #32
johnadlertech's Avatar
So you were able to keep the stock fey fob and add remote start. Cool. Any idea if it can be done with the intellikey on an 05? I like it and dont want to trash that whole system. I also dont want to tack on a completely independant system and have another key fob. I was told when I bought the car it was impossiable. But the salesman has already been wrong on a few other things.
Old Jan 5, 2006 | 05:16 PM
  #33
pp7's Avatar
pp7
Another question. How do you turn the car off with remote start on an 05 with ikey? Do you switch the key to the on position then off? Is there a way to turn the engine off with the remote start system as well?
Old Jan 6, 2006 | 12:03 AM
  #34
rupdog326's Avatar
I cannot answer for 05 with I key. To turn the engine you just press the lock 3 times. If you run to the store or any other quick errand and you want to keep the engine running, press the lock button 3 times with the key in the ignition, then remove key, the engine will stay running. When you return to the car, just reinsert key and turn to on.
chinee
Jun 10, 2024 07:48 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
JMSABO
Aug 4, 2015 11:58 AM
Texasscout
Jul 24, 2015 03:43 PM
apintojr
Jul 23, 2015 10:52 AM
