View Poll Results: What kind of synthetic oil do you use?
Mobil-1 5W-30
133
64.25%
Amsoil 5W-30
45
21.74%
Other (please specify)
29
14.01%
Voters: 207. You may not vote on this poll
Mobil-1 or Amsoil?
Originally Posted by AzianMakaveli
mobil 1 is over-rated, it cant handle high temperatures. i reccomend royal purple, amsoil or redline.
Give us proof that it doesn't hold up in high temperatures.
i've used mobil 1 on my honda at the tracks, along with amsoil and redline. i've had first hand experience. my oil temp was running hot on my 4th run in Willowsprings with M1.
I run Mobil 1 at the track in the Gcoupe and it has been fine. To address the issue of heat you need to understand that no oil is a limitless heat sink. You have a cooling system problem if you are overheating. That means you may need to do a few things to improve it. You may increase the size of your oil capacity by putting in a bigger pan (I run 7qts), increase the size of your radiator and its efficiency (like an aluminum Koyo with a core that is about three times the size of the stock plastic unit), try an additive like Redline Water Wetter, improve the airflow over the radiator, improve the airflow across the block by ducting and also venting the hood to draw off the hot air, and finally reduce engine load by dropping some weight off the car. I ran my car at the big track at Willow Springs in 106 degree temperatures and the needle was rock steady on normal. Tires were melting like brownies in the oven, but the engine temp with Mobil 1 was just fine. Redline, Castrol, Motul, Amsoil.......all outstanding products.
Originally Posted by 4U2NV
don't use either.. the best oil is Royal Purple high performance.. and using a K&N oil filter. might cost you a few pennies.. but hey its well worth it.. i goto a autmotive school and we did research on all oils and filters.. fram is the ****tiest filter. wat a POS.. mobile 1 is all BS bunch of BS addatives.
FYI guys, Mobil 1 is no longer a full synthetic....read here:
http://theoildrop.server101.com/foru...e=0#Post752599
Also many other topics. Mobil 1 changed there formula again where it now only has Group III instead of PAO in it.
Amsoil and Redline are now the only two who use PAO which is a better base stock.
That isn't what your posting really said............
agree Amsoil and Redline are good oils but this
posting is some guys opinion not fact! His opinion
doesn't prove ****. Mobil states that their base is
PAO and beyond that the won't tell you how they
make their stuff....would you?
