Estimated HP/TQ gains with the following mods??
Oct 12, 2005 | 08:26 PM
I have done a search, but you cannot ever add HP figures up. My initila performance mods are as follows:
05 6MT sedan
Stillen CAI, Z tube, New stillen Cat-back.
What performance gains can I expect with this set-up? 25-30 HP?
Does the Stillen exhaust come with the Y pipe as well? I am under the impression that it replace ecerything expect the cats and manifolds, correct?
Are there any other performance mods that are relatively inexpensive and that will yiled good results? I am trying to be mod-friendly in case of warranty issues and do not want to add headers or change cats.
Reply 0
Oct 13, 2005 | 02:34 AM
I think with that set up u will gain around 10 hp to the wheel.
Stillen exhaust comes with an X-pipe. it will replaces everything after your cats. Some mods that are inexpensive and good for the car are the z tube, engine grounding kit, k & n air filter,
Reply 0
Oct 13, 2005 | 09:36 AM
maybe 10hp/10tq.....but you do get more sound/noise.... I consider those sound mods.
Reply 0
Oct 13, 2005 | 12:25 PM
Does the plenum spacer make that much of a difference on the 05's? How about the plenum itself?
Reply 0
Oct 13, 2005 | 12:49 PM
I hear a TT kit is a pretty basic mod that is relatively inexpensive and yields pretty good HP gains. LOL. I think a grounding kit is a great idea. A pulley kit will get you a few HP by saving some weight etc. The K&N filter is a great mod for our motors. Not sure if the spacer will get you enoguh HP to justify the cost.
Reply 0
Oct 13, 2005 | 02:12 PM
Quote: Does the plenum spacer make that much of a difference on the 05's? How about the plenum itself?
its only for 05 and 06 models
its like 30HP+
Reply 0
Oct 15, 2005 | 06:12 PM
Quote: its only for 05 and 06 models
its like 30HP+
Actually there is little or no improvement on the 05 and 06. You should expect around 10+-rwhp on an 03 or 04.
Learn before you post.
Reply 0
Oct 15, 2005 | 07:28 PM
The first mod you should do is gears - then the Stillen CAI is a great choice, follow that up with the crank pulley, to a y-pipe and get rid of the stock resonator for an 18" glass pack...you'll get a good sound improvement without any drone and an increase in torque and top end. The gears will really make it all happen.
The Stillen exhaust is great - noisy - but going dual 2.5" pipe is TOO much breathing without doing internals on the car. Convert the pipe to 2.5" with the stillen y-pipe and keep your stock muffler - you'll be so much happier and get more your dollar in the end.
Unless your going FI - don't waste your money on anything else other than wheels/suspension - and that's much of a waste if you have the perf packg.
Take it from someone who has doen all the good stuff - except FI.
Reply 0
Oct 15, 2005 | 07:31 PM
One more - go for a short shifter and lightened flywheel too...
Reply 0
Oct 15, 2005 | 07:36 PM
Can you put a lightened flywheel on a 5AT?
Reply 0
Oct 15, 2005 | 07:43 PM
Quote: Can you put a lightened flywheel on a 5AT?
hmmm...where would you install that flywheeel on an AT????????????
hmmm............
hmmmmmmmmmmmmm............................
Assuming there wasn't a mis-type - the original post show MT
Ohh...there's a great place for a flywheel...before the CLUTCH!!!!
Reply 0
Oct 15, 2005 | 08:56 PM
Quote: Actually there is little or no improvement on the 05 and 06. You should expect around 10+-rwhp on an 03 or 04.
Yes, it DOES help the 05's. However, it only works on the 05 automatics. It doesn't do any good for the manuals.
I'm referring to the Motordyne spacers (in case you guys are talking about something else.
I have an 05 auto and it DID make a noticable difference.
Reply 0
Oct 15, 2005 | 08:58 PM
its like 30HP+
There's a spacer that makes 30+ hp on the '05 and '06? Have I missed something?
I know that I've been away from the boards for a little while, but 30+ hp with a spacer? Somebody better fill me in on this one.
Reply 0
Oct 15, 2005 | 09:31 PM
Nevermind, I know the answer to my question now.
Reply 0
Oct 15, 2005 | 09:50 PM
The engine revs ar high RPM's the way it is. I couldn't imagine doing shorter gears. At 80 MPH on a 6 speed, it is reving sround 3k in 6 th gear. What gear ratios woud you recommend? How much do they usually run? The ECu would have to be reflashed as well to make use of the gears, right? The shorter gears will also decrease gas mileage due to the engine being at higher RPMS' at any given gear?
Reply 0
