GReddy Catch Can
Old Jan 29, 2006 | 02:01 PM
Lojacc's Avatar
GReddy Catch Can
what's up fellas (ladies?)
just some quick input, if you will: im wondering if i just wasted my beer money on this Greddy Catch Can cuz im looking to install it...but...uhh...i cant seem to fit it anywhere. AND it doesnt help that the instructions are in japanese.
anyone? bueller?
Old Jan 29, 2006 | 02:07 PM
Andy2434's Avatar
Good luck with your fittment and installation. I was actually thinking about getting the Stillen catch can.
Old Jan 29, 2006 | 03:51 PM
Lojacc's Avatar
thanks bro. i have no clue how this thing is going to fit inside the engine bay. it's probably a failed attempt unless i really start rearranging some stuff. i'll let you know what happens.
Old Jan 29, 2006 | 03:55 PM
GReddySetGO's Avatar
Its not that hard, just stick the box somewhere, and run 2 hoses.
Old Jan 29, 2006 | 03:58 PM
EricIsKlumzyee's Avatar
if u have a cold air just put it where the oem air box would go..
Old Jan 29, 2006 | 04:45 PM
Lojacc's Avatar
i was thinking that as well. my hesitation was that running the hoses too far would lead to problems.
Old Jan 29, 2006 | 06:10 PM
The length of the hose won't change anything.
Old Jan 29, 2006 | 07:19 PM
Ninja350Z's Avatar
Does this help?
Here is a photo of mine installed you should have more room under the hood than I do. Anyway hope this helps.
Old Jan 29, 2006 | 07:25 PM
Lojacc's Avatar
wow...gorgeous engine bay, bro. looks like you have ALOT going on underneath there!!
see, thing is, i f'd up by getting the vertical can. even still, i did not consider putting it directly behind the radiator. i will give that a shot and see how it works out.
thanks alot for the input guys!
Old Jan 29, 2006 | 07:27 PM
Andy2434's Avatar
Sweeet looking engine compartment.
Old Jan 29, 2006 | 11:41 PM
caskyline's Avatar
Former Vendor
Here's one mounted on a G.I did go through the inner fender well to mount it,but not to dificult.
Old Jan 30, 2006 | 10:58 AM
DaveB's Avatar
From what I've read, the VQ's have no need for an oil catch can. They just don't dump enough oil back into intake manifold unlike other motors like the GM LS-V8s, Ford Modular V8s, and some Honda/Toyota motors.
Old Jan 30, 2006 | 08:32 PM
Andy2434's Avatar
Dave,
I am pleased to read this. However, what is enough? Is there a certain amount which becomes detrimental to the engine and short of that, it's okay?
Old Jan 30, 2006 | 11:21 PM
DaveB's Avatar
Originally Posted by andy2434
Dave,
Well, let's just say if you road race or auto-x the car (ie lots of hard corners) and you burn oil in the process and/or get a stumble and puff of black smoke during these manuvers, then chances are an oil catch can would help out. Cars like GM's LS series and LT1 small blocks have very small valve covers and under high g loads, the oil in the rocker valley pools and gets sucked up by the PCV system and ingested by the engine. This isn't a good thing especially if the car is burning through 1/2 to 1 quart of oil an event. Many Honda B series motors, especially VTEC varients, have the same issue thanks to a very small/shallow valve cover. The VQ's on the other hand seem to have decently large valve covers and I've never heard of VQs burning oil during road race events. The VQ, by design, does get some oil blow by through the PCV system and into the intake manifold. However, the amount is miniscal. I've read lots of posts in here about the shock of finding some oil and residue in the lower intake manifold. It's fine and most engines do this.
Oil catch cans are very functional pieces assuming the motor in question can really use it, otherwise it's just some underhood eye candy.
Old Jan 30, 2006 | 11:27 PM
Andy2434's Avatar
Thank you, Dave.
