Just purchased the Autoenginuity OBDII w/ Nissan enhanced.
Oct 6, 2006 | 05:06 PM
  #91
is this group buy still available????
Reply 0
Oct 7, 2006 | 09:21 AM
  #92
I am sure that it can be arranged. We need a minimum of 10 people for the GB. If we can't arrange one in g35Driver then you might be able to find another nissan forum that is offering a GB.
I will see what I can find out from Jay @ autoenginuity.
Reply 0
Oct 2, 2007 | 07:06 PM
  #93
Quote: is this group buy still available????
You still asking who has this?
Reply 0
Jan 23, 2008 | 12:45 PM
  #94
Foo_G, I don't think you are on this forum much anymore but I'll reply anyway.
I was able to get to everything you mentioned but I could not confirm the timing. When trying to see what the ign #4 timing was, it was reading something really odd like -80 or something. It said that before/after. I'll have to play with the Grid and see if I can get something like -15 or -17 to show
Quote: got this from Jay at AE regarding the adv/ret of timing.
Use the Test OnBoard for that. It will always start at -2 deg. Then you can change it to whatever you want. The actuation is totally something else. To store the value hit Done. It’s not in the Help file because that’s for our product. Nissan commands instructions are on the screen in front of you and in their service guides. Because there are thousands of these and they are different for every vehicle it will never be in our Help file.
to check:
You can immediately check your results. Go to the Grid and add the Correct Ignition … and Correct Idle RPM … sensors. They wlll reflect the current setting.
Reply 0
Jan 30, 2008 | 02:32 PM
  #95
Anyone confirm how to check the timing?
Reply 0
Jul 25, 2008 | 03:52 PM
  #96
Any more development with this?
Cipher shows the current base timing, and if it has been retarded or advanced.
Reply 0
Aug 20, 2008 | 03:54 PM
  #97
What do you need to confirm? The timing? I advanced my timing via my Autoengunity. I'll have to fire it up to confirm and let you know what is says. (if that's what you're looking for)
Reply 0
Aug 20, 2008 | 04:14 PM
  #98
Was looking into OBD-II devices and saw this thread. Did they develop it any further from the last posts made?
Reply 0
Aug 20, 2008 | 06:05 PM
  #99
Not that I know of. to be honest, if you have tuning aspirations (na and "maybe" FI), I'd just go with the UpRev. As far as I know, they both offer just about the same diagnostics features OBDII and both have added Nissan only functions. But as you know Uprev has Osiris reflash capability and you can use their Cipher logs to aid in getting additional e-flashes.
Reply 0
Aug 20, 2008 | 06:27 PM
  #100
Man. . .I was just leaning towards getting the Autoingenuity. Guess I'll start looking back into a cipher/osirus. Can the osirus overwrite a technosquare reflash?
Reply 0
Aug 20, 2008 | 06:40 PM
  #101
Drew, I do believe OCG35 ran an TS 1st then went to Churches to get the Osiris reflash.
I guess I'll try to look into what OBDII stuff both makers offer. But offhand, I think they can both read/alter the same basic things.
Reply 0
Nov 14, 2009 | 12:47 PM
  #102
Brigning this back from the dead i know... Can the TS advance/retard timing all accross the rev range or only at idle targetting enigne idle settings? i'm interested in it for my G35 and Frontier, and the Cipher will cost double to work with both vehicles.
Reply 0
Nov 17, 2009 | 03:42 PM
  #103
The OBDII autoenguinity can only retard/advance 2 deg as that's the limit of the Nissan Consult control.
TS has complete control of the fuel and timing across the rpm range. But you can get just one CIPHER and two Osiris reflashes. Probably need to talk to Jared over at UpRev to confirm. You could also just get a reflash w/ no Cipher obdII cable if you can find an UpRev dealer near you in Canada
Reply 0
Nov 17, 2009 | 05:39 PM
  #104
So it does adjust it accross the map. Thanks, thats what i wanted to know.
Reply 0
Nov 17, 2009 | 05:44 PM
  #105
https://g35driver.com/forums/g35-sed...ml#post4701541
Reply 0
