Aluminum Under Tray (Splash Shield) for G35/350Z/G35X/G37/G37X
Yes. Still available. If your stock shroud is too short to reach then you probably need a custom front piece. What version on nismo bumper do you have?
Has any one bought these undertrays that has a nismo V1 front bumper? my stock under tray wont reach the bottom of the front bumper as the nismo V1 sits farther out.
Im wondering these will reach the nismo V1 front bumper or if i need a custom front piece.
Thanks in advance
Thanks in advance
Punishr - my shroud is designed to fit all stock locations. So if the stock shroud doesn't reach to your bumper this will not without modification. How much extension do you need in order to fit? Is is the same amount of drop as well, or does your bumper sit lower than stock?
This 2 threads explains exactly what im talking about.
https://g35driver.com/forums/norther...-attached.html
https://g35driver.com/forums/interio...ly-bumper.html
So you have the version that was made poorly for the under tray? There are ways to compensate ...it looks like the side will match but the middle won't. I can make a custom piece if you want. You need something to make it work.
Correct. The sides of the front part will match but the front of the front part(not sure if it makes sense) is not long enough.
Whats circled in yellow fits and its fine; however whats circled in red is what needs to be longer.
that would be great if you could make a custom piece to fit.
I would take a picture but my stock undertray got ripped off by the wind already and its somewhere on the side of the road
do these fit kuruma z bumpers?? i was never really able to get the stock undertray fit correctly as the kuruma z front sits lower then stock. LMK asap. My old one is now somewhere on the highway lol
In order to fit aftermarket bumpers that were not made with the same mounting locations as stock you will need a custom front piece. I can do it for you - it just takes a little extra time for it to be made. Also, for making custom parts you will have to pre-pay your order so I'm not left with custom components.
