Exterior-Vendor Includes spoilers, body kits, tail lights, gauges, shift knobs, and other styling components
Aluminum Under Tray (Splash Shield) for G35/350Z/G35X/G37/G37X
Old Aug 9, 2012 | 02:01 AM
  #121
TORETTO's Avatar
I want to get one of these, but I'm afraid the entire thing will just get yanked off in a matter of days. My undertray is about 1 1/4th inches off the ground and I smack it on the smallest bumps. Luckily the plastic things can bend and flex enough to not fall off completely. How would this cope with the impact?
Old Aug 9, 2012 | 03:06 PM
  #122
Tolboothwilley™'s Avatar
Originally Posted by matthewfuture
Hey Tolbooth, I was looking to get a brushed shield shipped to 78231. I also need the U-clips as well.
Thanks man!
Pm replied
This tucks up in compared to the stock shroud but still keeps adequate clearance for your engine oil pan and sways.. It follows the contours better and will hold up much better than the stock plastic. Being metal it can handle some abuse as well. I know a few that are really low who are rocking it.
Old Aug 10, 2012 | 03:28 AM
  #123
txcyko's Avatar
I need one. Can I get a pm.
Old Aug 13, 2012 | 10:45 PM
  #124
PM was sent to you TXcyko
Old Aug 14, 2012 | 10:20 AM
  #125
kaisar's Avatar
Are these custom undertrays turbo friendly?
Old Aug 14, 2012 | 01:24 PM
  #126
TORETTO's Avatar
i don't see why not. Are you planning on having an open dump tube facing down?
Old Aug 15, 2012 | 03:42 AM
  #127
It really depends on your setup. GENERALLY it should work great. If you have a lot of tubing/lines running below the radiator support/oil pan area than probably not. Most people would not even think about routing that way though.
Old Aug 17, 2012 | 03:33 AM
  #128
viceversa's Avatar
still available?
Old Aug 17, 2012 | 11:09 AM
  #129
yes, still avaliable
Old Aug 17, 2012 | 08:45 PM
  #130
viceversa's Avatar
sent you a PM no response?
Old Aug 17, 2012 | 10:00 PM
  #131
i replied - thought I had replied to you earlier - sorry about that.
Old Aug 19, 2012 | 12:00 PM
  #132
G35X_204's Avatar
pm sent
Old Aug 20, 2012 | 02:47 AM
  #133
all pms replied
Old Aug 21, 2012 | 10:40 PM
  #134
TheDizzle's Avatar
03 G35 Coupe, brushed/non powder coated shipped to 75226 please!
Old Aug 23, 2012 | 12:34 PM
  #135
pms replied, shrouds shipped
