Weird Issue with Gas Gauge...
Old Aug 6, 2007 | 10:57 PM
g8tor20's Avatar
FGC's official flip flopper
Heres my post in the G-spot section....
https://g35driver.com/forums/showthr...23#post2179923
Anyone hear of this before?
Old Aug 7, 2007 | 01:44 AM
escobar929's Avatar
hmm, never heard of that before
Old Aug 7, 2007 | 02:27 AM
w0ady's Avatar
fgc moderator
here you go jason. i remember infiniti doing some tsb's on the fuel lines and such but i cant find the exact problems. either way, this tsb shows that they are having problems if that have a tsb on replacing the sensor.
http://www.infinitihelp.com/Ownershi.../ITB05-043.htm
Old Aug 7, 2007 | 09:17 PM
sameo2's Avatar
yep sound like u got problem with your fuel sender at fuel pump.easy fix and yes there is a tsb for that.
Old Aug 7, 2007 | 09:31 PM
g8tor20's Avatar
Thanks guys!
Old Aug 7, 2007 | 09:55 PM
Audible Mayhem's Avatar
someone was a little rough with your walbro install, just replace the small part on the fuel bucket that has the arm that moves up and down...
Old Aug 7, 2007 | 10:56 PM
Gilley's Avatar
That fixed my issue. I had 1/4 tank showing on the gauge when the car ran out of gas. That part fixed the problem.
Old Aug 7, 2007 | 11:53 PM
BlackWindEXE's Avatar
mine always show less than what i have. whenever i fill it up fully. it's always a little off. never had your problem though
Old Aug 8, 2007 | 03:40 PM
DFaz's Avatar
I have never had that problem, however something similiar. My gas gauge would show only half of what was in the tank. This lead to a few fill ups where I thought I would take 15 or so gallons when it would only take 8-10. I brought it to Infiniti and turns out it was a bad fuel sensor. Thus reading the incorrect fuel limit. I had it replaced and everything is fine. I have an 03 Coupe. Something you might want to check into.
Old Aug 8, 2007 | 03:42 PM
g8tor20's Avatar
I never did the Walbro stuff. I stuck with stock fuel system.
It's workin fine again. I'll keep an eye on it and take it over to Lokey if it starts giving me any trouble.
But thanks for all the replies....
Old Aug 8, 2007 | 03:55 PM
WILD121's Avatar
so what your saying is your going to the lokey meet
mtlruss
Dec 20, 2015 01:51 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
leo38cheng
Nov 12, 2015 06:49 PM
MsFitFern
Sep 7, 2015 02:45 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
