5AT w/ tranny coolers chime in.
Old Oct 16, 2006 | 12:54 AM
  #31
Gee3Five's Avatar
Originally Posted by roneski
Sorry that I missed this thread but it looks like most everything has already been said. Just got done installing a cooler on a friends G who recently had his turbo installed.
Thanks Ty.
Old Oct 17, 2006 | 02:52 PM
  #32
roneski's Avatar
Devil's Advocate
No problem man.
I got around to installing my tranny filter last night. It seems to have made a surprising difference. The shifts seem "happier". They were kind of cranky before.
I'm going to run this filter for a couple of thousand miles then pull it and cut it open to see how much crud it ends up trapping.
Old Oct 17, 2006 | 02:59 PM
  #33
rookie's Avatar
Look forward to the filter results. How did your fluid look?
Old Oct 17, 2006 | 03:01 PM
  #34
roneski's Avatar
Devil's Advocate
Fluid looked fine. I didn't fully drain it or anything though. That's just based off of what I saw spill out of the lines when I rerouted them.
It seems to have helped out with my low RPM slippage. Fairly surprising.
Old Oct 17, 2006 | 04:10 PM
  #35
rcdash's Avatar
How did you replace the spilled fluid? Or was it not significant loss? I've got my parts. Now I'm trying to decide how to sync w/ a tranny flush at the dealer. Should I install it first but not hook up, let them flush, then hook it up? Or hook it all up right before the flush (minus the filter I guess)?
Old Oct 17, 2006 | 04:11 PM
  #36
roneski's Avatar
Devil's Advocate
I put about 3/4 quarts of new fluid back into it. There wasn't a lot of spillage but it's a pretty big filter. I figured a at least a half quart just for it's volume.
Old Oct 17, 2006 | 05:50 PM
  #37
rcdash's Avatar
My filter is directional (must be installed in the direction of flow). Can someone confirm which is the line returning back to the transmission?
Old Oct 17, 2006 | 05:54 PM
  #38
roneski's Avatar
Devil's Advocate
The passenger side into the radiator is coming from the transmission. The drivers side is the return.
Old Oct 17, 2006 | 08:47 PM
  #39
rcdash's Avatar
thank you! Was having a devil of a time finding a diagram in the service manual that showed the flow direction...
Old May 25, 2012 | 12:44 AM
  #40
G35thrilla's Avatar
bringing this back from the dead, but this is a super informative thread.
thank you
kuruptone
Feb 22, 2006 02:47 PM
rcdash
SouthEast
Jul 25, 2005 09:34 PM
CT_Texas
Forced Induction
Jul 10, 2005 04:08 PM
SoCalTed
Drag
52
May 17, 2005 10:42 PM
SoCalTed
21
Nov 21, 2004 09:46 PM
