G35 Greddy TT Install + Fully built Short Block + Kinetix Plenum
Old Jul 7, 2007 | 09:02 PM
  #31
sharif@forged's Avatar
Originally Posted by Gman2004
Sam and Sharif have been known to disagree from time to time, but since Sam is the one working on my car I'll go with what he recommends. Could it be the ARP 2000 although not as strong the L19's provide enough clamping force to prevent headlift without the possibility of corroding like L19's which is why Sam is recommending them???
The L19 studs can be trqed down to a higher level than the ARP2000's. Sam has a valid point, and so do I, and in speaking with ARP, I feel confident using the L19's.
We had a basketcase car that was brought to our shop for fix up, and it had the L19's installed and run for 1 year. When we took the engine apart, there were no signs of corrossion whatsoever. That's really all the evidence I have.
I respect Sam's opinion, and he respects mine as well. It's all good.
Gman, is your car at GTM?
Old Jul 10, 2007 | 08:44 AM
  #32
Gman2004's Avatar
My car is not at GTM yet. I am taking a road trip to Socal for a business trip next week so since I will be in Sam's neck of the woods I am going to drop it off and just fly home. I have to go back again next month so I will fly out and drive back home. Should be a fun drive home with an extra 100whp.
Old Jul 10, 2007 | 10:31 AM
  #33
Awesome man...have a good time, and enjoy the drive!
Old Jul 10, 2007 | 11:08 AM
  #34
Sinister350GT's Avatar
My builder Kyle @ imports parts pro suggested the ARP 2000 head stud kit. I am retaining my stock valves and seats. and just going with a grind anf flow for the heads.
Question: Is the U-Tec pretty simple to use? program changes of the fly and such.
What about LSD options?
Will the stock fuel system be able to handel this load?
Old Jul 10, 2007 | 11:16 AM
  #35
Nismo G's Avatar
Originally Posted by GXCLUSIV
With those goals, sell the SSV and emanage, save up for FCon Vpro for your EM.
Fcon ftmfw!
-Sean
Old Jul 10, 2007 | 03:16 PM
  #36
Originally Posted by Nismo G
Fcon ftmfw!
-Sean
I did not want to go with the Fcon from HKS. THe U-Tec from TurboXS will give me the results I am looking for.
Where would I find an LSD for m car?
Old Jul 22, 2007 | 11:00 AM
  #37
ekwc's Avatar
Oil Pan
Sinister350GT,
Is the oil pan of the kit made out of steel painted in black or aluminum? I have seen some pictures of the kit that the oil pan is in silver color.
Thanks.
Old Jul 22, 2007 | 04:44 PM
  #38
The greddy kits use a cast aluminum oil pan.
Old Aug 8, 2007 | 01:47 PM
  #39
http://www3.telus.net/cwdance/The%20...otor%20001.jpg
So after 12 weeks of gathering and ordering parts. I have entered the Finial Assembly Stage.
Above is a picture of the Block we are currently staging the turbo setup. There is still alot of prep that needs to take place on the car.
More pics to come.
Old Aug 8, 2007 | 06:55 PM
  #40
ttrank's Avatar
Grocery getter
Very cool.
All you guys are making me want to build mine so bad...
Old Aug 9, 2007 | 11:42 PM
  #41
nyqueenz's Avatar
Originally Posted by Sinister350GT
ARP head studs; ARP Main studs; Cometic Head gaskets are going into this build.
As for how its going to get to the road? For now it will be a dyno queen.
My wife will kill me if I spend any more this year.
However. There will be 19X10.5 on the rear and 8.5 in the front for wheels.
Lowering 1" with springs. Sway bars and traction bars.
Thats about all I have planned so far.
What do you suggest?
Let me help you out a lill
SEPC or ACT 6 or 4 PAD Heavy duty Pres plate clutch kit,
LTW flywheel,
longer gears in your diff,
may need axles(strong ones) if going ova 650 HP,
Stoptech, or Brembo brake kit or higher (4 to 8 pistions),
Goodridge Steel lines,
GOOD compound tires, At least a 285 or bigger for rear if you going 10.5 rear,
not just springs. get a coilover kit (Tein)
Race fuel,
Oil cooler,
Proper tuning.
Old Aug 9, 2007 | 11:49 PM
  #42
nyqueenz's Avatar
Originally Posted by ttrank
Very cool.
My shop will swap motors your stock for a built one.. around 5Gs.
Old Aug 9, 2007 | 11:51 PM
  #43
GreenGoblin's Avatar
The goblin resurrection
looking good brother wish I had the flow do something like that
Old Sep 26, 2007 | 10:06 PM
  #44
http://www3.telus.net/cwdance/The%20%22G%22/1011_0037.jpg
http://www3.telus.net/cwdance/The%20...2/101_0037.JPG
Old Oct 4, 2007 | 05:54 PM
  #45
New Hood Installed
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
