Safest, most economical FI
Hey guys. I've always been interested in forced induction, but afraid of the consequences of destroying a stock engine block. What would be the safest kit to run with the most HP (turbo or supercharger). After spending 30k on a car, I'm also on a budget. I know I can do the supercharger install myself, but turbo might require a shop. Also, can you guys post how many miles on your systems and any problems caused by them.
Thanks!!
The following FI systems seem to have the best following:
Stillen roots SC
-easy to install/engine warranty/inexpensive
--must install new hood or cowl to stock hood
Procharger SC
-easy to install/no hood mods needed/no oil pan tap
--moderatly priced
Turbo -Greddy/JWT
-no engine HP loss/power is usually higher/no special hood
--EXPENSIVE/difficult to install/some inherent lag/heat issues
Thanks!!
Stillen roots SC
Procharger SC
--moderatly priced
Turbo -Greddy/JWT
I like Procharger the most
Don't like Stillen cuz it needs that ugly hood
If you looking for something reliable then Procharger is they way to go.
Will give you enough power to be fast and still keep your engine in one piece.
Procharger SC
--moderatly priced
Turbo -Greddy/JWT
Procharger SC
--moderatly priced
Turbo -Greddy/JWT
JWT is the fastest spooling Turbo out there so if you complaining about lag around 2.5k-3K then your standard is to high.
But you need to tap into the oil for the Vortec...complicates the install.
Check this thread for ATI blown motors.
http://www.my350z.com/forum/showthread.php?t=50488
joe603-I feel you bro. I am looking to go FI pretty soon and weighing all of these options is driving me nuts. lol!! Each kit has its pros/cons. But regardless of which kit you go with, no kit is 100% safe and a blown engine is always a possibility with FI no matter how "safe" you are. So just make sure you have some back-up funds available just in case.
Originally Posted by AthenG
Procharger is the least popular in term of Centrifugal SC. Vortech holds that title and Vortech is also being used as a standard for reliability.
For a diy install the roots sp appears to be the easiest, next the vortech and then the single turbo setups. Frankly I hate spers and sp cars (they tend to break really easily, and aren't good for road courses, touge, or really hard driving, but to each their own. With any kit though you need to have it tuned and you wont get the gains and reliability everyone else gets until you do exhaust, the cooling upgrades, transmission upgrades, Engine Management upgrades, etc. so consider everything that you need before and after FI before you go that route.
The be best you can do now is just find all the best components that will give you that peace of mind. ATI doesn't have a good EMU and the same with Greddy and maybe JWT. Getting a Tuner kit is the way to go and buy the parts that you think is necessary. The upcoming STS Turbo isn't going to blow your mind but it is better option than most Supercharger and it comes with some nice parts. Tial 38mm Wastegate, Tial 50mm Blow off valve, all JET HOT coated pipes, 440CC injectors, Walbro 255LPH fuel pump, Turbo XS UTEC, and Garret turbo. The STS will also be the easiest install of all FI since it is Rear-Mounted.
Originally Posted by b00stedjustin
the jwt turbo is the same turbo in the greddy kit, which is the lancer turbo, so lets not single the JWT out.
I had a Vortech. Great SC, but I couldnt find anyone to tune it in my area, so I couldnt keep it
