ApS single TuRbO
Old Jul 12, 2007 | 07:38 PM
  #46
Jeff92se's Avatar
Red Card Crew
But after reading, you haven't decided. But since you were considering, I thought you would know what you are buying.
No problem
Originally Posted by VQ Hotness
I found a good deal on a ASP T 3,500 Shipped and i can do the install my self. It comes with everything needed. And i figure it has plenty of room to gain more then 400 whp. Figure if I want more power ill just buy some pistons and rods and up the boost a little more. Prob get a good 500 whp out of it. Then i could always spray if i wanted more power. I think over 600 wheel is a little to much for a DD, plus i would have to have some head work done. And if i didnt go over 600whp with a TT i would find it pointless going TT. But with the ST i can still get the headwork and spray a little more IF i needed.
I figure the extra 2 grand+ i save from doing the install my self and going with a ST i can invest toward Pistons and rods.
Thats just me.
But thanks for letting me know about the APS fitting..
Old Jul 12, 2007 | 08:19 PM
  #47
da mayor's Avatar
Originally Posted by ttrank
On your stock block?!?
i'm leaving this up to Vinny Ten and go by his words. If anyone was at Nissan/Infiniti Day the past weekend all the cars were and still are daily drivers and run hard... especially through NY driving.
Old Jul 14, 2007 | 01:55 PM
  #48
tig488's Avatar
trust me DO NOT GET THE APS SINGLE TURBO KIT. there are multiple issues with that kit ESPECIALLY if you install it yourself. i had my kit on my car for almost 2 years and it never ran 100%. i was always fixing things and tweaking it. i even replaced several parts. youve got oil leaks, leaking seals, smoking, losing boost, etc etc.
and you cannot just replace it with a bigger turbo, you cant even put a true GT35R on it, the compressor housing that comes with the kit is way smaller so it will fit. the turbo sits about half a cm from the frame rail and other parts of the car. there is no way in hell the kit is capable of 500hp at the wheels. several have tried, all have failed.
trust me its not worth it, even for that price.
Old Jul 14, 2007 | 06:07 PM
  #49
panda007's Avatar
i was about to quote this man's posts from way way back.
the ST has had problems with the internal wastegate/actuators. not saying everyone with the ST did, but there has been a reported amount of people with it. not to mention, with the APS ST, please be aware of the oil scavenge pump as some failed and had smoking issues. there's an external wastegate option for the kit (or was it custom?) regardless, i think turbonetics is the only ST to go in my opinion. otherwise, if you are serious about building a FI monster, go twins... it's worth the investment.
Old Jul 19, 2007 | 06:30 PM
  #50
Orlando333's Avatar
Stay away for the APS ST. The Turbo sits way too low. The oil scavenge pump issue is a bitch. The seals on the Turbo leak. It has good power but stay away, unless you like having your car in the shop.
Old Jul 19, 2007 | 10:32 PM
  #51
gsxr_rx1's Avatar
Are those with the Greddy TT kits having any issues? Oil leaks etc? How reliable is this kit for a DD? How many miles would you expect to get out of the engine with a good tune and approx. 380-400 whp?
Old Jul 19, 2007 | 10:59 PM
  #52
jbone's Avatar
'04.5 Black 6MT Coupe
Would an oil scavenge canister help or a better aftermarket pump?
Old Jul 19, 2007 | 11:34 PM
  #53
tig488's Avatar
the oil scavenge reservoir would be a start, and MOCAL makes a nice pump that might be better, but there really isnt any room to add a reservoir.
Old Jul 20, 2007 | 12:02 PM
  #54
jbone's Avatar
Thanks, I'll check it out
g.spot
May 9, 2016 10:54 PM
Learned Hand
Oct 1, 2015 09:02 AM
9tray turbo
Sep 29, 2015 10:22 PM
mikemf8
Sep 3, 2015 08:01 PM
