Does everyone get these big difference in numbers on different Dyno's ??
Just thought you G/Z guys would get a kick out of this......
I was invited to a Corvette Club Time attack event this past Sunday. Came first in the Modified bracket by 8 seconds. One of the ZO6 guys protested my win. So they sent my car to the garage for inspection
They were looking for some injection kit ( NOS ),because one of the flag guys said he heard spraying sounds on the back straight
THAT WAS THE BOV
They asked me AGAIN how much HP... I told them 444rwhp ( because thats what Sharif got on the DD dyno with controller off and 501 @ 14.5 psi). They protested again and said it had more. They hooked it up to the Dyno and to my fing surprise 558 rwhp at 564 tq @ 14.5 psi, But I ran it at 11psi. They disqualified me on the spot
I called Sharif a few seconds later, because I wanted to know if they are trying to screw me out of a win
But Sharif said it sounds about right. They want to disconnect my Boost Control and for me to repeat the runs.... or run in the Open Class with the Race prepped race cars...Yeah right
it aint worth $3000 and a trophy for me to let them disconnect anything on my car.
Has any one else gotten the kind of Dyno differences
it aint worth $3000 and a trophy for me to let them disconnect anything on my car. Has any one else gotten the kind of Dyno differences
wow, i would be venting as well man. I just put an interesting read about different dynos.
Check it out and tell me what you think...
https://g35driver.com/forums/lounge-off-topic/175973-truth-dynos.html
-Sean
-Sean
Originally Posted by izmir41500
why didn't you dyno at 11 psi, since that's what you ran?
https://g35driver.com/forums/showthread.php?t=175973
-Sean
-Sean
That seem right, Sharif's dyno read the lowest of all sponsored dyno. If I'm not mistaken at your power level you should hit 40-60 more hp on a dynojet compared to Sharif's #, they don't call it a heartbreaker dyno for nothing
LMAO thats where it got its name!?!
-Sean
that sucks, but i'm a bit surprised that you were unaware of the different types of dynos and numbers they produce...
i knew exactly what you were going to say before I even finished reading your post lol....perhaps you could convince them that their dyno reads high?
btw, you shouldn't have any problems running just on the wastegate spring if they disconnect the EBC...i'm surprised they are so **** that they won't even honor the honor code
pretty pathetic if you ask me
i don't remember your original post, but what psi is your spring rated at? you shouldn't have a problem running on the wastegate spring...
-Sean
pretty pathetic if you ask meI knew that Sharif's dyno numbers were lower.....but I did not know it was that much
Nismo G.....
I did tell them that their numbers are crazy...and I even showed them a copy of Sharif's dyno sheet....but they showed me the rules.... If protested...they will only consider their results.
Originally Posted by XKR
617G....
Nismo G.....
Nismo G.....
just run it again with the EBC off and prove them wrong
maybe next time, we can tie one turbo behind it's back....that might give these poor sports a chance to compete.
Well, nice driving anyways Mike...you kicked their *****.
LMAO...
I will try that next time Sharif
Mike
Originally Posted by CruisnGcoupe
lol th r just ad cause u laid the smack down so hard
I know that you mean......
Mike
joedaddy1
Aug 12, 2015 04:01 PM
