Is the supercharger worth it?
Old Oct 11, 2007 | 10:22 PM
  #46
FI'ed G's Avatar
Originally Posted by Hexxum001
I have a before dyno. I am at 384whp right now. Being installed at GTM right now are a MD spacer, FI HFC's, Aquamist meth/water injection kit and my GReddy Evo TT exhaust was installed by Street Image a few weeks ago. I am also getting the Exedy clutch and lightened flywheel combo. Sam is going to re-tune and see what she puts down now. I should easily be over 400whp but Sam is going to do a somewhat conservative tune for safety and reliability so we will see.
with all those chit, I'll be really really disappointed if you don't hit 400+whp. Give us an update on the Water/Meth coz I'm thinking of adding one by spring.
Old Oct 11, 2007 | 11:59 PM
  #47
Hexxum001's Avatar
Definitely. I will post up the dyno when I get my G back.
Old Oct 12, 2007 | 12:45 AM
  #48
imalazeeass's Avatar
sam was trying to convince me to follow your footsteps.. i almost agreed to.. but my wallet disagreed..
Old Oct 12, 2007 | 12:56 AM
  #49
Hexxum001's Avatar
That's what credit cards are for!
DO IT!! DO IT!! DO IT!!
Old Oct 12, 2007 | 05:30 PM
  #50
MAZyar's Avatar
well, i do have the spacer (3/8), ztube and k&n filter, but the gain, although good, is not as well as i like it to be.
the other day, i test drove an evo, and i wanted to see if how i can get similar boost / kick / acceleration.
Old Oct 12, 2007 | 10:16 PM
  #51
aero's Avatar
If you want that kind of kick, you're gonna have to go FI. Imagine this:
http://videos.streetfire.net/search/...9500d2b4bf.htm
[not my car, but mine sounds the same, Vortech with an HKS SSQV blow off valve]
Old Oct 12, 2007 | 11:35 PM
  #52
Skaterbasist's Avatar
Retired SuperMod
Damn Hex your getting up there quickly huh... Cams would be sweet (ofcourse pricey).
Old Oct 13, 2007 | 11:16 AM
  #53
MAZyar's Avatar
That vidoe is sick. Nice setup, and nice kick. how fast is the 0-60 on those two g35's? Is the SC and blow off valves the only mods on them?
Old Oct 13, 2007 | 12:36 PM
  #54
aero's Avatar
I don't know the owners, but I'm guessing the car in the beginning has something on the exhaust side too, could be test pipes or HFCs, or maybe one of those and a cat-back system, sounds a little more raspy than stock. But the jet-engine noise and the hiss are purely the SC and SSQV (respectively). It's probably at least as quick as my car (at worst 4.8 seconds). But if he has a smaller pulley, headers, an ignition amplifier, upgraded fuel system etc., who knows, could be in the low 4's.
Old Oct 15, 2007 | 10:08 PM
  #55
MAZyar's Avatar
How about nitro? It seems its much cheaper, and just as powerfull as SC (I think.)
Any thoughts on it? (specifically safetly issues?)
Old Oct 16, 2007 | 12:17 AM
  #56
G35Asian's Avatar
WAYYY LESS CONSISTENT is all I have to say about nitrous. I had it on one of my old cars so I know this first hand. It kind of gets annoying when everything is not running optimum on & off and is constantly inconsistent. Boost is way more fun and consistent . Just my 2 cents.....
Old Oct 16, 2007 | 12:57 AM
  #57
TIAN's Avatar
Hold The Line
I think im leaning more over getting the vortetch sc with the aftercooler and that direct shot of nitrous in the aftercooloer. Whats that called by the way?
How much do u think that setup would run me? Im lookin to go 400whp or under. I dont wanna build
Old Oct 16, 2007 | 02:07 AM
  #58
G35Asian's Avatar
Its called an intercooler sprayer . With your basic breathing mods (i.e. test pipes, exhaust, plenum spacer, etc) and a 3.12 pulley you should be able to hit 400's in the winter.
Old Oct 16, 2007 | 02:11 AM
  #59
TIAN's Avatar
Hold The Line
Woo! How much dis gonna cost me brotha?
Old Oct 16, 2007 | 10:47 AM
  #60
aero's Avatar
one meeeellion dollars!
You may be able to find a Vortech tuner kit for about $3500. Check out the group buy section in the marketplace. Performance Factory has some good deals on Vortechs, awesome guys to do business with too. But if you go with the tuner kit, you'll need engine management (i.e. UTEC), which is gonna run you another $800-900. And then you'll need a MAP sensor for the UTEC. Labor will probably vary widely depending on who does it, but an experienced shop may be the best bet.
As for the nitrous, no idea. But if it were me, I'd go all out and get something crazy like the NCM-2 control module. You can set it to purge only at a specific throttle setting. Turn on the unit, accelerate, and at WOT you purge.
http://www.venovus.com/
