driveline on FI G'S?
Old Nov 2, 2007 | 02:27 AM
g35ctuner's Avatar
all you forced induction people have you had any problems with your drivline or axle's/differential? if so what kind of hp are you putting down and what fix's have you found? looking to go fi in the near future but i want to make sure she can handle the power reliably thanks.
Old Nov 2, 2007 | 08:36 PM
Xblackg35X's Avatar
none yet lol aint been able to drive it really either though
Old Nov 2, 2007 | 09:37 PM
wongy's Avatar
I'm using a ATS carbon LSD and DSS level 5 axles, although the axles were probably a bit of overkill i wanted the added insurance. what sort of power goals are you thinking of making?
Old Nov 2, 2007 | 10:11 PM
Glex25's Avatar
Administrator
My rear suspension hops off the line most annoying.
The only way to minimize or eliminate that is to run your suspension softer in the rear which i don't like doing.
running Act Heavy Duty clutch and Act streetlite flywheel.
Old Nov 3, 2007 | 10:35 AM
XKR's Avatar
XKR
Fully built and running over 500rwhp with ATS carbon LSD ...no problems
Old Nov 5, 2007 | 07:58 PM
sharif@forged's Avatar
Most of the axle breaking occurs at the drag strip, or if you accelerate hard on a really bumpy stretch of road.
For maximum reliability, I would suggest a set of Level 2 DSS axles, and a good diff, such as the Carbonetics Carbon LSD, or the Quiafe. Both are nice and quiet on the street.
Old Nov 5, 2007 | 09:23 PM
QuadCam's Avatar
all stock drive line.....although I'm putting down 410/400 at the wheels
Old Nov 7, 2007 | 07:45 PM
g35ctuner's Avatar
nice, that's probably the set up im going to go with.
Old Nov 22, 2007 | 10:36 PM
Sylvan lake V35's Avatar
i have similar #s I am all stock. But looking to do a clutch soon and with the DRs I will be running this year axels will be next. If you dont drag race stock driveline will work but the clutch will be on borrowed time.
infinitiway
Aug 8, 2017 12:38 PM
DriveLineSales
Aug 17, 2009 02:28 PM
DriveLineSales
Exterior-Vendor
11
Aug 12, 2009 03:11 PM
