Running lean at idle
Old Nov 24, 2007 | 05:31 PM
pabg35's Avatar
Simple Ax6 G
today I installed a grounding kit it had sitting in my garage for a while, I also checked my spark plugs on the driver side. So I took off the mass air flow sensor to get to the plugs. Put everything back, turned on my car and I was running lean 16-17.5 at idle
yes I did disconnect my battery before the install
reset my ecu already
No Service Engine soon Light On
took it for a drive around the block, still no engine light on runs good when the gas pedal is pressed. help!
Vortech
have ecu reflased
utec
aem a/f gauge
Old Nov 26, 2007 | 03:46 PM
waijai's Avatar
i.love.gold
possibly you're getting a leak where you removed the MAF...unmetered air may be getting into the intake. double check all the couplings.
Old Nov 26, 2007 | 03:48 PM
FastDontLie's Avatar
...we dont need roads...
^^^ Thats what I was saying at first.
Old Nov 26, 2007 | 04:01 PM
pabg35's Avatar
Simple Ax6 G
thanks Will and Daniel
Freeman186
Sep 6, 2023 10:07 AM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Rhinos7777
Sep 6, 2015 05:36 PM
Jnm07
Sep 5, 2015 01:16 AM
n2fooz
Sep 4, 2015 07:46 PM
