Building it up.
Old Dec 23, 2007 | 06:36 PM
booger's Avatar
Originally Posted by urban
The harder you drive the harder the shifts are, for example the way I drive daily is very easy and I leave it in Auto so the car shifts earlier and you don't feel the jerk to each gear but if I get aggresive then the shifts are a little harder, especially the 3rd to 4th. Now when Sam took it for a spin yesterday he put it in Manu mode and floored the car and shifted at 6k from 1st to 2nd and 2nd to 3rd and the shifts are hard and chirp the tires.
This is exactly how mine drives also . When I take off easy in D mode or manual mode with very little gas , the 1st to 2nd shift is very hard [ meaning it clunks or bangs the rear end gears] . It was even worse with the 3.5 rear gears . I have gone back to the 3.2 gears since .
Old Dec 23, 2007 | 08:45 PM
urban's Avatar
booger, do you have any guages in your car to monitor the system, I am trying to keep mine somehow hidden but was just wondering what you have.
Old Dec 23, 2007 | 09:40 PM
booger's Avatar
Only the Zietronix for A/F , boost , EGT's mounted right in front of my eye's on the dash .
Old Dec 24, 2007 | 01:46 AM
Mr_pharmD's Avatar
Hey booger, yours sound alittle different then what Urban described bc yours still clunks/ bangs when u take off ez or with little throttle (say under 3K rpm). His description sounds more what I was trying to explain about it jerking (aka hard shifts).
Old Dec 24, 2007 | 01:57 AM
urban's Avatar
Let me clarify as there are words like "jerk", "bang" and "clunk" being used, I think we are all probably refering to the same thing as it is a hard sound to describe. Don't want to confuse the thread more but mine is a thud when it changes and the jerk is really the car accelerating once it's done, I do not get a metallic sound of metal to metal like clunk or bang when changing gears and mine is fine at low rpms which is anything below 3k. The car in D actually shifts early like 2500rpms and you can feel it like you do in stock form.
Hope that made sense.
Old Dec 24, 2007 | 08:32 AM
booger's Avatar
good explination . Yes mine thuds , bangs , or clunks what ever you wanna call it . But mine is most noticable from 1st to 2nd with very light throttle . If I give it enough gas so it shift a little later , [ above 3000rpm ] its fine and just shifts hard and fast .
Old Dec 25, 2007 | 09:39 AM
MardiGrasMax's Avatar
Check out the Blitz I-Color MMD or SBC. I have the I-Color SBC and some add on sensors. I will be able to monitor boost pressure, AFR, oil temp, oil pressure, fuel pressure, water temp all on the one multi display of the I-Color SBC. Its pretty small and can be mounted easily or hidden away and taken out when you need to monitor things closely.
Old Dec 25, 2007 | 05:16 PM
urban's Avatar
I have the Blitz SBC in the car now but because I have the FCon Vpro I have decided to go with the HKS F-Con Navigator.
Old Dec 25, 2007 | 08:46 PM
SBC I-Color or plain SBC?
HKS Navigator must be nice!
Old Dec 26, 2007 | 12:29 AM
urban's Avatar
Just the plain SBC for checking my boost, one reason why I need the Navigator now.
Old Dec 26, 2007 | 12:55 AM
TURBOTOM's Avatar
a.k.a kleicoupe
Ohhh man, I have some reserch to do on AT's. This thread just confuses me. Correct me if I am wrong, but the thud/clunk noise on our AT trannys is "normal" and shouldnt be cause for concern????
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
