FI crowd, what oil do you use?
About to go JWT-tt and I just wanted to hear from the FI crowd about what oil they are using? The oil analysis thread is very informative, but it was more helpful when I was stock, as that is what all the trending is targeting really. I had been using Castrol GTX until now. I am thinking of going Mobil1 0w-40. What is everyone else using on their FI setup?
Originally Posted by Hexxum001
Mobil Synthetic 0w-40. That's what I use. Good stuff!
Originally Posted by Xblackg35X
i use castrol syntec 5-30 the stuff in the the black bottle.
+1, this the the result of my test after 2500 miles of driving.
Originally Posted by athenG
Ok, here is my result after using Mobile1 0W40 for 2500miles. I have a Single Turbo running 8psi around 360whp on my Stock Motor. This 2500 miles are all hard driven and lots of WOT Pull since I was adjusting my A/F for the Winter Driving. I only drive my car on the Weekend so I go WOT every chance I get My oil was almost black when I changed them so I was surprise that it did hold pretty good. My car is pretty much stock except the Turbo and Mrev+. I think I can still push a few more hundred miles but I'm happy to change my oil at 2.5K miles
And this is Resolute's response.
Originally Posted by Resolute
Lead, Copper and Chromium are all very good. The Fe is high, but it always is with M1. Not to worry. For a FI engine, this looks very good. You only have 2500 miles on it, I'd say you could do an easy 4k even though you're boosted. Nice looking sample from a turbo'd engine, this oil's doing well for you. I think QuadCam is giving Rotella T-Syn a shot in his FI VQ, it will be interesting to see if it's worth trying for your engine as well. Of course, if you stay with the M1 0W-40 you'll be making a good choice for sure, since the results in your engine are already proven to be just fine. I only wonder if there's a brand that might lower the Fe wear.
Will
Will
This is QuadCam's comment on the hype about Motule 300V
Originally Posted by QuadCam
Finally, I have my UOA for the Rotella T-Syn 5W40. This oil looks to be a good one, but I'll let Will give his analysis. Also, Blackstone is correct in regards to the lead content. I am guilty of running Citgo 110; I ran a whole tank of it (about 18 gallons) toward the end of this oil sample (probably in the last 750-1000 miles of use). My previous oil was Motul 300V 5W40. You can see that the Motul UOA came back with much higher levels of Aluminum and Iron than in the Rotella UOA. I guess I won't be switching back overhyped, overpriced Motul. Here it is:
Mobile 0w40 is proven to hold on Stock Motor at mild boost (below 10psi) and it is cheap and readily available in any Autostore.
Good stuff! Where did these reports come from??
The Mobile1 0W40 was from my car and Check the Oil Thread in MY350Z. I think you guys should at least do it once since it is only $22. This will give you a peace of mind that your oil is actually doing its jog.
Originally Posted by ttrank
Oh look another FI oil thread...
M1 15W50 in the summer and 5W30 in the winter.
