To be safe...
Old Feb 12, 2008 | 09:15 PM
nyqueenz's Avatar
To be safe...
Just to be on the safe side..
Would anyone recommend me doing a head gasket on the stock VQ35 to lower the high compression on the stock setup. I'm not really ready to build the VQ35 engine so to be on the safe side I think this would be good option if I want to run FI without any worries.
By the way is the stock compression on the VQ35 11.1 or 10.5?
Old Feb 12, 2008 | 10:05 PM
nyqueenz's Avatar
Originally Posted by HomieG35
Never really thought about this.... would it make a sealing issue? I mean... how thick of a gasket would you need to make any significant difference?
HKS Metal Head Gaskets
The HKS VQ35DE Metal Head Gaskets are 0.7mm thick and feature a 4-layer stopper-type structure. The stopper-type structure employs a stopper ring around each combustion chamber that is molded into the head gasket for a precise and strengthened seal. The factory head gasket is only made from 3 layers and has a bead-type structure. A bead-type head gasket only uses a raised bead to seal the combustion chamber. The HKS VQ35DE Metal Head Gaskets are targeted for forced induction and high-horsepower naturally aspirated applications.
Old Feb 12, 2008 | 10:29 PM
nyqueenz's Avatar
Hmm, so far I'm finding examples of other guys using these, mainly S2000's and Audi TT's, but they don't say how thick the gaskets are.
Most are extreme though, like the S2K's lowers it a 1 full mark, while the TT's is lowered nearly 2, from 10.30:1 to 8.5:1.
I also see the stock compression ratio for the G as 10.3:1, but '07 may be 11.0:1, the sights I'm finding for the G aren't that credible.
I know with BMWs we are running 10.5:1 with a M52 multi layered steel HG .120" thick it would drop the compression 8.1
Old Feb 13, 2008 | 09:52 AM
nyqueenz's Avatar
Why would they say this is for high hp NA engines, when they thrive off of high compression?
i really don't know maybe cause of the seal.. but i know if you wanna run boost the larger HG is good to lower the CR
Old Feb 13, 2008 | 10:31 AM
FI'ed G's Avatar
This was a trick we used on my Honda days but it is easy to do it on a 4 banger. Try replacing a head gasket on a VQ and you'll realize that you might as well do a mile rebuild coz it is a pain.
Lartytiejdke3
Mar 1, 2014 11:31 AM
Wemet19
Forced Induction
27
Nov 22, 2009 07:32 PM
C h r i s
Aug 24, 2009 10:16 PM
boi
Canada
18
Jan 2, 2009 09:02 AM
