HKS Gt Supercharger released!!
Originally Posted by EvolutionGSR
Is there a particular reason why you need to take out the spacer? I have one on right now too.
How much more did it cost to have the intercooler and pipes black? Are they being anodized or radiator painted or...??
. ) Otherwise, there is no reason to take it out.I do not remember the cost of the black out. I do remember asking about it being anodized and .....I dont remember the answer.
TBG Dad!!!! DO NOT GET THE TS HOOD, IT WILL HIT THE SUPERCHARGER!!! How do i know? I have a TS Hood
It doesn't clear, of course it shuts but it touches the supercharger, and you just have to put pressure and shut it down, leaves marks
So I do not suggest it!!!!!!!
stock hood clears fine. the sand casted part of the inlet of the sc does rub ever so slightly on the stock hood fiberglass insulation but with a utility knife you can outline where it rubs and relieve the strain. It does not touch the actual hood.
So basically the hood would have to be modified near the second vent to be able to fit without bending, if I'm understanding right. In your guess-timate, how much would you say? Less than 1/8"? Maybe I'll wait and try and find a good deal on a Chargespeed CF hood. The different venting should make it ok and it looks much better than the VIS Slayer.
Also, from the pics (@GTM), it looks like your IC piping is pushing on your KurumaZ?
All things going well, I get the car back tomorrow. I'll post the pics I took later but everything is coming along nicely and I can not wait to drive it tomorrow. I'm still not sure how the TS will work but its believed we can do a slight modification to the vent in question without making it look weird. We shall see.
First off, Thank You Sam @GTM for making the impossible possible!
I'm really enjoying this setup and the added power. I really need some wider wheels and stikier tires.
As far as numbers: 391.8 whp and 356.3 trq, Dynapack.
I'm scanning the dyno printouts and will post with some pics and initial impressions in a few.
