Well My FI Days Have Come To An End.....
#46
Originally Posted by Hi-Tech_G
Sounds like your rod went through the oil pan. I have had this happen with a 97 GS-R. I was running a Turbonetics Kit and the same thing happened....driving home from hanging out with some friends....loud clank followed by a pop and an oil trail about a 1000 feet long....and clouds of smoke. Sorry to hear man. This just makes me change my mind more and more about boosting the G.
#47
Originally Posted by Moog
VQ motor for sale local: http://dallas.craigslist.org/pts/619409389.html
Short Block packages: http://www.importpartspro.com/shblpa.html
#49
Originally Posted by g35man04
explain more what you mean by Fuel Setup..Oil level I am assuming it was full..I had just picked it up from the dealer after having the oil changed 5 days ago...I have a JWT Oil Pan spacer and told them that I needed an extra QT of oil...that was over the phone...did my service advisor tell the mechanic...I dont know....So if I only had 5 QTR's I would be starved for oil which would result in blowing the engine...
#50
#52
#53
A/F Was running just fine..I have RC enterprise 550cc injectors. I was told that my fuel was being maxed out at that RPM range.....everything was good on A/F....10.2-10.6 or 7 is what it was normally at.
If the duty cycle on your injectors is above 85 - 90% then you could have been looking too lean at the top of the RPM range. I'm still running stock injectors but only pushing ~6psi and I think I am around 90 - 95% duty cycle at redline on the stock injectors. I'm just not going to mess with anything on mine because it's been solid the way it is...
#56
Originally Posted by BeerViper
So you were told that the fuel was being maxed out at which RPM range? If your fuel is being maxed out at any usable RPM then you either need a higher pressure fuel pump or higher flowing injectors (and I see you already had 550cc RC injectors). I assume you had a walbro FP to go along with your upgraded injectors?
I had the Walbro fuel pump as well....I dont know I am still waiting on some info from Cameron.
#57
Simple Ax6 G
on
whats the difference in stage 1, stage 2, and stage 3...are those built blocks?
#59
Sorry to hear about your loss.
It sounds from what I have read so far that the car was only tuned up to a certain RPM, which is pretty low at 5200 and leaves so much room for issues to occur especially when our cars do their best work towards redline. If the car was not tuned to redline then who knows what AF your were at in that RPM band....just sounds like trouble to me.
I am also guessing this was on a stock block?
Lastly your numbers are pretty high for only 5200rpm, I can see many people wishing they had those numbers at redline.
Hope your future plans work out great
