WTF? 267hp?
Old Jul 3, 2008 | 07:39 PM
  #76
Hexxum001's Avatar
That's a good call. GRD is a good shop and they will take care of you.
Old Jul 3, 2008 | 08:09 PM
  #77
Hydrochoad's Avatar
ok, so as I said...i found that the digital fmu was still installed with all settings on 0. I can only imagine that this is not good. Im going to disconnect it from the car before I take it to the tuner. Any objections?
Old Jul 4, 2008 | 11:35 PM
  #78
Hydrochoad's Avatar
Yeah, so I told the tuner to disconnect the Aeromotive DFMU because it wasnt needed. Instead, the just basically shut it off without providing power to the second fuel pump. So, I turned the DFMU back on by adjusting the sliders to about max. Im assuming its ok to max it out, because the fuel return system will compensate for any excess fuel being pushed through.
.....I just tested my theory, and the A/F gauge stays a nice constant 11.5. Even at 7 lbs where before it would lean out completely. I still plan on getting it tuned, but at least now, Im not risking my engine as bad as it was before. I would still like to just disconnect it and just run power from the other pump to the second.
Old Jul 11, 2008 | 01:31 PM
  #79
v35's Avatar
v35
well i had a same set up first time... running Pe TT kit with stock motor, 6psi... i dynoed on dynojet and had about 330ish whp(with only technosquare ecu reflash).... and then i built the motor/ installed utec and boosted to 9psi. result was 395whp with 420ish lb torque...(used 380cc injectors that came with the kit).
Old Jul 14, 2008 | 11:12 PM
  #80
Hydrochoad's Avatar
screw it - im shipping it off to AAM.
Old Jul 19, 2008 | 03:40 AM
  #81
sTony's Avatar
bro, Sound Performance is in the suburbs of Chicago and has TONS of experience with the VQ. Check out their web site and give them a call..
www.spracingonline.com
Old Jul 19, 2008 | 07:51 AM
  #82
Glex25's Avatar
Administrator
+1 on SPracing
They know their ish
Old Sep 4, 2008 | 03:28 PM
  #83
Hydrochoad's Avatar
My car is FINALLY at AAM after a huge hassle of trucking companies - LONG STORY. Anyway, I will keep yall posted on the dyno and numbers...
Old Sep 4, 2008 | 03:31 PM
  #84
GreenGoblin's Avatar
The goblin resurrection
Good luck
Old Sep 4, 2008 | 07:42 PM
  #85
sheplex02's Avatar
yeah bro.. good luck!!! at least with all the knowledge AAM has they should mos def be able to get your car feeling alot better!!
itll be funny though when you get your car back cuz its gonna feel completely different..
Old Sep 5, 2008 | 12:10 AM
  #86
serturbo's Avatar
Please keep us updated on the progress of your tune. I'm sure we are all interested and would like to know that your car is alright
By the way, just for interest sake, how much did it cost for the trucking company to ship our car to AAM? How far away is the shop from your place. I can't imagine it being cheap with the price of diesel being as high as it is..
Old Sep 5, 2008 | 08:26 AM
  #87
escobar929's Avatar
best of luck bro, 267 is pretty whack for a TT
i was dynoing that when i just had intake/exhaust and headers
Old Sep 5, 2008 | 08:42 AM
  #88
Hydrochoad's Avatar
Actually Express Auto (Broker) did it for like 695, so it wasnt too bad. I live in iowa, so its a pretty decent distance. I will probably fly out to pick it up when its done though.
Old Sep 10, 2008 | 12:24 PM
  #89
sheplex02's Avatar
SO?????? updates????
Old Sep 10, 2008 | 02:00 PM
  #90
Hydrochoad's Avatar
well,
not sure if I can afford it now, i guess it needs the manifold repaired (about 800 or so), new plugs (400.00) two new rear tires (700.00) tune (700.00) and few other minor things...Grand total was like 4000.00. To avoid cost and just get a minor tune (rear tires required and plugs recommended) it was still 2700.00. 500.00 was them covering shipping.
Sux... I know I can do plugs for cheaper, and the tires. I will prob have them fix the manifold and ship it back. Once I get the other stuff done, I will drive it up for tune...
