Anyone find my 1.5psi laying around?
Old Aug 12, 2008 | 11:16 PM
Jtrain's Avatar
Cuz I've definitely lost it. I've got the AEM truboost and I noticed since my coil replacement episode that I'm not gettin my full 9.3-9.6 PSI... I noticed my missing 30ish horsepower on the highway and then noticed my PSI wouldn't go over 8.3.
I gave it a day or two and ripped it open all the way through third.. after the run i consulted the gauge for the max it read... gave me the
"HI.... 8.7" Which was better, but I would never boost under 9... I'd go to 10 before I'd underboost.
The beginning of the end? Back to the motor build shopping list?
Old Aug 12, 2008 | 11:37 PM
Jtrain's Avatar
It's been 90+ degrees all summer. I mean the 10psi was when it was definitely cooler. But I've been in high 9psi in the high 90's for 100% sure.
Old Aug 12, 2008 | 11:43 PM
GreenGoblin's Avatar
The goblin resurrection
nice thread title sorry bout your problems as of late
Old Aug 12, 2008 | 11:52 PM
Jtrain's Avatar
I know a motor build would fix all this crap- but I really just wanna keep it running well in the mean time if possible :/
Thanks for the regards.
Old Aug 13, 2008 | 09:47 AM
FI'ed G's Avatar
You gain over 30whp on just 1psi?
Old Aug 13, 2008 | 10:18 AM
Jtrain's Avatar
Just guessing- I'm probably not far off on a TT set up, it was REALLY noticeable.
Old Aug 13, 2008 | 11:30 AM
str8dum1's Avatar
why not just turn up the boost controller?
Old Aug 13, 2008 | 01:32 PM
escobar929's Avatar
is your AFR still the same?
maybe a boost leak somewhere?
Old Aug 13, 2008 | 01:39 PM
rcdash's Avatar
How are you regulating boost? Duty cycle or closed loop feedback? I'm not familiar with the AEM unit. What EMS?
Old Aug 13, 2008 | 05:59 PM
Jtrain's Avatar
That sounds like a horrible idea actually.
Unlikely its a leak. I did check it and reconnect everything just in case though. Doesn't sound, look or feel like one ( I've had several )
HKS:iS EMU
Old Aug 13, 2008 | 08:16 PM
str8dum1's Avatar
i can easily see over 1-2psi difference between days of varying temps.
Whats the wastegate spring pressure?
Boost can be down if there's a leak or its significantly hotter outside. both of which you said cannot be. so that means your wastegate isnt working right. Sure you didnt burn a hole thru your wastegaet vaccuum line?
i guess you cant log IAT or boost can you? If you can, up the boost and watch the IAT's.
Old Aug 13, 2008 | 08:22 PM
Jtrain's Avatar
I'm down to like 7.5 psi-- anyone got a freaking PDF for AEM tru boost? It's gotta be this stupid thing.
Old Aug 13, 2008 | 08:35 PM
escobar929's Avatar
is there a way to reset the AEM gauge? not very familiar w/ it
although if you feel the loss in power, unless its a mental thing
Old Aug 13, 2008 | 08:42 PM
Jtrain's Avatar
No- You loose 1psi you can feel it
You loose 2 you WILL feel it.
I need the PDF manual or something.
eljefe7070g35
Sep 11, 2015 09:28 AM
Terry_G35
Sep 10, 2015 08:17 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
G35CO
Sep 4, 2015 09:27 AM
