Retune with new plenum?
Old Oct 7, 2008 | 06:50 PM
  #31
SDGeneralCounsel's Avatar
Originally Posted by Mike@RiversideInfiniti
The good stuff is always hard to find... I try to buy my brake pads in bulk since availability is so limited
I dunno. The whole import industry has hit it hard because of the recession, so nobody is really keeping anything in stock anymore. I make a point in calling to check on availability before I purchase something online or even through Scott.
Old Oct 7, 2008 | 06:51 PM
  #32
mIKE's Avatar
Even back in the day HC+ pads weren't easy to find...
I'm sure Cosworth can build to order, but I don't even want to know what the lead time is...
Old Oct 7, 2008 | 07:44 PM
  #33
TBG_Dad's Avatar
Originally Posted by Canadian
Damn, I haven't looked but I thought that since the Cosworths have been out for a year now they might be more widely available. Guess not
from my350z.com
Originally Posted by turismo
I believe they stopped production for a bit, to fix the flaws in the design. I think there where issues with the end caps hold boost above 16psi(Eaglegreen had issues at 18 I believe).
from my350z.com
Originally Posted by kwame@z1
That is correct, production was stopped shortly to make some design revisions.
Now that its been revised, they will be more accessable but then maybe not because of the economy. who knows? I would still love to have one in satin finish.
Old Oct 7, 2008 | 07:53 PM
  #34
Jeff92se's Avatar
Red Card Crew
Unless you know someone that had done exactly what you are going, there is no real way to know if you need a tune or not. I'd GUESS since this replaces the upper and lower sections and because this unit is supposed to flow better, a tune could be in order. You could "probably" get away with driving it around as long as you don't get into the open loop portions of your tune.
If you have a UTEC or similar, can't you datalog after the install to verify if you need a tune? Even someone with a Cipher (if you are 05+ w/ widebands) should be able to do some datalogging for you
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
Oggie.mayes
Sep 27, 2015 04:10 PM
