upgrading to the 2.87 serp pulley.
Old Jan 29, 2009 | 12:42 PM
Hexxum001's Avatar
Actually, I went with the 2.87 right from the start so I really don't know how much faster it made me. I do 95% city driving so my gas mileage really stinks. I am running the HKS FCon iS which was tuned by Sam @ GTM.
Old Jan 29, 2009 | 01:55 PM
ska12's Avatar
so u suggest the 440 or the 550 injectors. Ive heard so much diversity on which ones are the best. And what would be the difference between the two
Old Jan 29, 2009 | 02:36 PM
Hexxum001's Avatar
Well, you should be fine with 440's but I personally would just get the 550's. It just gives you that added cushion in case you want to upgrade more in the future. But 440's would work fine too.
Old Jan 29, 2009 | 04:31 PM
ska12's Avatar
so with the 2.87, walbro, 440s, utec, plenum spacer, and Hks Hi power exhaust i should safely be pushing at 400whp?
Old Jan 29, 2009 | 04:43 PM
GreenGoblin's Avatar
The goblin resurrection
^ I think that you would be close
Old Jan 29, 2009 | 04:47 PM
ska12's Avatar
Plenum
Whats the best Plenum Spacer for non revup engines.
Old Jan 29, 2009 | 06:20 PM
Hexxum001's Avatar
I would add hfc's or test pipes to your list and a good tune. That should have you right around that mark. As far as the plenum spacer, I would recommend a Motordyne spacer.
Old Jan 30, 2009 | 10:02 AM
ska12's Avatar
I just keep hearing the motordyne and spacer does not work good for the non revups. Also Wouldnt the HKS True DuAL exhaust come with hi flow cats? If i got the full system
Old Jan 30, 2009 | 12:55 PM
will4992's Avatar
I've heard nothing but good things about motordyne spacers for non revups. I would get the motordyne 5/16" spacer (http://www.motordyneengineering.com/G35.php) Also, im pretty sure that the hks doesnt come with hfc. I believe it is a cat back system.
Old Jan 30, 2009 | 03:07 PM
Hexxum001's Avatar
My first exhaust for my G was HKS. It's cat back so you would need to get some hfc's separately.
Old Jan 30, 2009 | 09:35 PM
ska12's Avatar
Face thinking he knows everything
this has nothing to do with you face... STAY OUT OF IT.
Old Jan 31, 2009 | 12:25 PM
will4992's Avatar
don't face me **** actin like i don't know everything.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
