STS turbo successsssss!
awesome kit definately works everything was very straight forward kit comes97 % complete for the g35 100% for the z. im running anywhere from 5-7psi i can switch with boost controller. installed 1000 miles ago running excellent at WOT under boost the aem wideband reads 10.9 a:f which is pretty safe looking to me. utec preprogramed ecxu with 5 map settings easily switched. map1 test map (most conservative) map 2 same fuel as 1 but more aggressive spark, map3 if 1 and 2 are to rich in the 10.0 a:f then fuel mapping will be adjusted to run leaner. map 4 for custom tune map 5 for valet driving.
no numbers yet will be getting the tune and posting them soon and none of the components hang lower than the factory exhaust. turbo outlet temps @ 8psi is about 225F. thats alot . by the time it gets into my engine its 125F. lets see you get those numbers without methanol you front mounted turbos.
