5AT + FI = Questions
Old Jul 20, 2009 | 10:44 AM
phunkenstein's Avatar
I don't have the money now, but I am trying to do my research on going Forced Induction on my 2004 Laser Red G Coupe.
I've looked at a couple of kits, and the one I really have my eye on right now is the GT Motorsports DE Turn Key Twin Turbo Kit (I am looking into the Turn Key vs Tuner versions). I don't know if Stage 1 would suffice, I need to read further into the outputs of each.
For AT Transmission upgrades, I've read a Torque Converter and Oil Cooler are required. Any other trans upgrades needed to prevent stock trans damage?
Thanks in advance guys. Other tips may be helpful!
-Brian
Old Jul 20, 2009 | 10:47 AM
O HELLA OEM's Avatar
best bet is to search the forced induction section
and do research from there.
or PM some vendors on here im sure they'll be
happy to help you out
GL
Old Jul 20, 2009 | 02:56 PM
j_marinelli's Avatar
Valvebody I would say is a must as well. Depending on how many miles you have on the tranny, might even consider a full built tranny.
Old Jul 20, 2009 | 03:30 PM
IrockAG35's Avatar
Ohio G Club moderator
not true..im FI/AT no troubles with tranny but i do have a blown ring..i recommend doing your pistons/rings/rods.but i guess if your going to do it,you may as well do your tranny while your at it..lol
Old Jul 20, 2009 | 03:48 PM
Canadian's Avatar
Canada, eh?
You will want at least a valve body upgrade with a TT setup. Make sure you run low boost and don't go over 400whp unless you have the money for a new built motor.
PM if you want help picking out a tranny cooler, VB upgrade, or if you even want to go fully built.
Old Jul 20, 2009 | 05:15 PM
rcdash's Avatar
^+1. VB + trans cooler (a big one!).
Old Jul 20, 2009 | 07:18 PM
tiguy99's Avatar
Canadian, I'm going to be hitting you up soon. I want to upgrade my vb and add a GTM cooler soon.
Are you guys running an trans temp guage too? That's what I want to do. Make sure I know what's going on down there at all times you know
Old Jul 20, 2009 | 07:28 PM
chinabean's Avatar
Powerlab single turbo @ 4-6psi = good DD boosted G, if you're interested with that I may help you. But of course you'll need all the upgrades for the transmission Valve body upgrade and such as others are telling you
Old Jul 20, 2009 | 08:15 PM
Canadian's Avatar
Canada, eh?
Sounds good, just hit me up whenever. I don't have a trans temp gauge yet but plan on doing it soon whenever I get around to doing my new gauge install...probably in the next 1-2 months. IMO unless you track your car when you are going repeated WOT runs you don't need a trans temp gauge. I overheated my trans on the track near the last lap of every session but if you aren't tracking you should be fine.
Old Jul 21, 2009 | 10:47 PM
urban's Avatar
I think this question comes up like every other month, it's all covered before.
VB, TC ,oil cooler, tranny cooler and if you want even more trq capabilities upgrade the tranny itself.
Check my garage if you like.
Old Jul 21, 2009 | 11:57 PM
tiguy99's Avatar
Sounds about right.... Urban did you have the 5AT stuff done all at once or in intervals?
Definitely! What happened to your trans after it overheated? Did it start slipping?
Old Jul 22, 2009 | 12:36 AM
urban's Avatar
I had a VB upgrade put in first but then I raised the rev. limiter as I kept hitting it. Soon afterwards I felt the clutchpacks starting to slip so I had the whole remaining package upgraded at the same time.
Old Jul 22, 2009 | 05:08 AM
nyqueenz's Avatar
-Brian
anything with the word tuner kit behind it i would advise going bulit..
Old Jul 22, 2009 | 04:22 PM
djamps's Avatar
6mt needs upgraded clutch.
5at needs upgraded valve body.
Trq converter is not manditory, but will certainly help you lay down more consistent power curves.
To advise against that is nothing more than FUD. It is only a matter of time before your tranny bites the dust otherwise.
Old Jul 23, 2009 | 12:19 AM
Canadian's Avatar
Canada, eh?
Well actually it didn't overheat, but it was about to. I was just doin my lap and then the display that shows the gear went into 4th gear, even when I didn't shift. It wouldn't go out of 4th at all. Then a few seconds later the display went blank and the AT check light came on and the car wouldn't up shift or downshift at all. After I got back to the pits I let it cool down and it was fine, but it did it again near the end of every session (4 sessions in the day).
The tranny went into limp mode to prevent it from overheating, so it didn't actually overheat but it could have.
