For experienced
Old Aug 8, 2009 | 06:44 PM
  #61
Sylvan lake V35's Avatar
So all the guys that have done big horsepower builds say it can't be done based on experience. The guy that has an intake plenum spacer says it can be done. Untill someone dose it for under under 20K I will side with the guys that have experience.
Old Aug 8, 2009 | 06:56 PM
  #62
GT-ER's Avatar
Yup, happens often...but I have no problem with you guys being "right" and me being "wrong"...it's not my money.
Old Aug 8, 2009 | 07:43 PM
  #63
Chef-j's Avatar
Originally Posted by GT-ER
Hehe...Got me.
I have no problem with people throwing money at a setup...as I said before ( over and over again )...if I COULD...I would too. No disrespect...but just because 99% of people do it one way doesn't mean there can't be 1% that does it another.
Regardless...if anyone wants me to "prove" it...then just sent me $20K and I'll do it. If not, then I can't prove it because I don't have the cash. If that's what it takes for you guys to open your mind a little...then all I can say is you win I guess.
Why don't you open a credit card and send it to me. I can make that happen if you let me buy used stuff. ( but not guranteed it will realiable.) And you gotta stop throw roll eyes, i really want to pull that eye *****.
Old Aug 8, 2009 | 07:57 PM
  #64
TTG35forT's Avatar
So wait...can you or can't you? Cause I recall reading a lot of posts that say the engine would blow up...yet it seems that it won't...I dunno. The topic wasn't about what was "preferred"...it was asking if anyone has tried it. It's pretty obvious what compression is preffered.
Go back and read my posts. I didn't say you "can't" run 11.5:1 compression with a FI motor and get 500whp, I said that I didn't understand why you would want to do so... IMO, the safety margin you are sacrificing is not worth the little bit of extra torque you will get in the low rpm range. Nonetheless, please proceed with your build. I'm curious to how it turns out.
Old Aug 8, 2009 | 08:00 PM
  #65
Chef-j's Avatar
I don't think high compression = blow engine, i would say it is ok. If i'm going to spend money on build, i would go low compression build, so that can hold more boost and for future. If engine build correctly with good tune/good support mods, i would say it will be fine even with high compression/boost.
But honestly, i have no experience with build motor, that's just my " thought". i would let "pro" to answer your question
Freeman186
Sep 6, 2023 10:07 AM
G35-R
Nov 7, 2015 01:21 PM
cmesidewayz
Sep 29, 2015 09:28 PM
vamarris
Sep 26, 2015 12:56 PM
