My LS2/350z---PT88 single turbo build.
#33
#37
Who did you order this oil pan from since the hinson one you had before was not upto par? Also, is the only option to go solid motor mounts? Do you feel a lot of vibration in the car at idle? Im sure your new cam will make it even better
. Did you or do you plan on any sort of chassis reinforcement to deal with all the extra torque you will be putting down? ..cant wait for updates on the build!
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
#43
