JWT Turbo numbers
#31
on
sorry... iam not trying to cause problems.... i was just checking to make sure its the same setup... I did take your advice and research your setup... iam going to get the 700hp setup with a mild tune to about 550 whp. As for the lake thing.... ive been stuck on the navy base here where i had to worry about getting water in the stock air slit. Hard rain for 1 hour = 1 to 2 foot puddle outside of gate 5.... you could use a fanboat down terminal blvd. Norfolk used to be a swamp that they drained... kinda like new orleans
as for the kit ill have to get the tubing changed for the filter. thank for letting me know about the gtm... has anyone installed this thier selves.
Alot of posts about installing different kits DIY. At one time the JWT was the hot thing.... But IMO the dealer only thing is killed it....I can speak on both because I have owned both..i am not a person that promotes a product I have never tried.... Yes there are other good kits out there from SFR. SP, Intense... But I will leave it to those who own those kits to speak on it.
Good luck
