Upper/lower Plenum
Old May 27, 2010 | 09:54 AM
Romanski85's Avatar
Upper/lower Plenum
Installing long tube headers next week. Any recommandations if I should go with both the upper n lower plenum or just the upper? Car is NA with jdm intake and dual 2.5" exhaust. Tuning it after the header install.
Old May 27, 2010 | 11:04 AM
SxExCx's Avatar
You question isnt too clear. What model is you G? Replacing your lower plenum with an MREV2? Are you looking for an aftermarket upper plenum? Have you considered a spacer? What exactly is a "JDM intake"?
Old May 27, 2010 | 11:57 AM
Romanski85's Avatar
I'm sorry. Your right, that wasn't very clear.
I have an 05 6spd Coupe. I wanted to replace both the upper and lower plenums. For the lower plenum I was looking at the Motordyne MREV 2 and for the upper Kinetix Racing V+ Plenum. I don't really know if the two will work properly in conjunction to each other as well as if the installation of both of them at the same time is even possible.. Correction on the intake, it's a Injen SP 1993P air intake that simply replaces the stock intake. *
Old May 27, 2010 | 12:14 PM
jonnylaw's Avatar
Since you have a revup engine, get a MD 5/16 spacer and a MREV2.
Old May 27, 2010 | 12:38 PM
Romanski85's Avatar
Ok! Thank you!
Old May 27, 2010 | 12:53 PM
SxExCx's Avatar
+1...you should only consider the MREV2 and 5/16 spacer with the OEM upper plenum. If you want to dress it up at the same time, you should check out my polished plenums and EVERY other aluminum engine part. Click the link in my signature to see my work.
Old May 27, 2010 | 04:52 PM
Romanski85's Avatar
Why would a 5/16 spacer be better than the kinetics V+ Plenum? Also, there are 3 different 5/16s plenums to choose from. The basic, copper and the other one. Which one to choose....
Old May 27, 2010 | 05:01 PM
SxExCx's Avatar
5/16 has been proved better time after time. The Kinetix V+ is ugly and has cracked or warped in a few situations. Get the isothermal MD kit.
Old May 27, 2010 | 05:18 PM
Romanski85's Avatar
This is exactly why G35driver is the ****! Thx for the help guys!! Will post my dyno tune read outs once that takes place.
Old May 27, 2010 | 05:41 PM
GreenGoblin's Avatar
The goblin resurrection
For future reference this has nothing to do with F.I.
Old Jun 2, 2010 | 12:09 PM
Lee R's Avatar
Also...is it really called a lower plenum?
Old Jul 23, 2012 | 05:36 PM
flexican77's Avatar
I think I asked about it, but I forgot... is that mvrev2 any good with the DE engine?
Old Jul 23, 2012 | 05:44 PM
unvmyg's Avatar
05 is a rev-up DE so the merv works with your engine. 04 and later models not so good. Can someone else please confirm? Thanks
Old Jul 23, 2012 | 06:16 PM
Tolboothwilley™'s Avatar
MREV2 works with the DE and rev-up engines...
it is essentially the same lower plenum for the 2003-2004s with some porting/milling/work done.
The gains are not work the $450 but many have taken their stock lower plenum and done work to them to improved performanc. Some people have bought the MREV2 - but gains are nominal....4-6 HP in upper rpm range mostly.
Old Jul 23, 2012 | 06:36 PM
Jeff92se's Avatar
Red Card Crew
If you want to do any custom porting, I have a non-rev up lower/upper plenum for sale.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
Oggie.mayes
Sep 27, 2015 04:10 PM
