Rev-Up Vortech Oil Change recommendations
Old Nov 7, 2010 | 09:41 AM
GeezNuts's Avatar
Question Rev-Up Vortech Oil Change recommendations
Ok - so i've been running my V3 supercharger on my 06 coupe for about 6,000 miles now and i've been burning some oil...
I currently run Mobil 1 5w-30 and change it every 4000 or so miles...
I've been having to add a decent bit throughout the cycle and was contemplating a switch of oil weights or even moving back to conventional.
Should i try a 10 weight or perhaps a mix of 10 and 5, or maybe switch back to a 5 or 10 weight conventional?
Does anyone have any thoughts or similar experiences?
Old Nov 7, 2010 | 06:35 PM
GeezNuts's Avatar
bump to the top
Old Nov 16, 2010 | 04:29 PM
LowUFO's Avatar
It's fairly common for the Rev-up motors to burn oil. I have to add about a quart a month. Since to you are supercharged, the dealer won't warranty the motor for the oil consumption issue. (I'm in the same boat as you).
Ian
Old Nov 16, 2010 | 06:16 PM
GeezNuts's Avatar
I know they won't warranty the engine anymore... i dealt with the dealer prior to installing any engine mods...
once i saw that i was SOL with the shady dealer and eclipsed the 60,000 mile mark - i installed the supercharger
- I am trying to determine if i should go to a non synthetic or just use a heavier weight synthetic... perhaps a 10W-40
I am also submitting my oil to blackstone labs to have it analyzed for some insight...
Old Nov 19, 2010 | 11:47 PM
SleekStyle's Avatar
Riverside infiniti warrantys moded cars
Old Jan 27, 2011 | 01:38 PM
GeezNuts's Avatar
Just an FYI for those who may find this while searching in the future:
I switched to Mobil 1 10W -30 and i am burning less oil, car is running well and burning less oil. I plan to run this weight oil for awhile and i will send the oil sample to Blackstone for analysis next oil change
Old Jan 27, 2011 | 01:42 PM
Frankieg35's Avatar
Just keep a close eye on it.. My buddy was burning oil with his v3 vortech on a revup shortly after it blew up..
Old Jan 27, 2011 | 02:30 PM
GeezNuts's Avatar
ha ha - mine will blow at some point, that is a given... hopefully not before i have a chance to build another one next year though - If so, i'll be pimpin' my 01 Grand Am a bit more than i would have hoped
11bEMT
May 27, 2022 03:13 PM
Ednica87
Sep 5, 2015 02:59 AM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
ClwMike
Jul 23, 2015 12:55 PM
