Cut back of cubby door for gauges?
Old Nov 26, 2010 | 01:06 PM
eZg's Avatar
eZg
I'm thinking of trying to fit a couple gauges into the cubby where a stock nav would be located if originally equipped.
The door seems hallow and a dremel would make short work of it. I'd like to be able to close the door and have the gauges hidden when not in use.
Thought I'd check to see if anyone has tried......
Thanks,
George
Old Nov 26, 2010 | 09:46 PM
Scootch's Avatar
here are a few pix of what i found, i know its not exactly what your talking about but i know i have seen people do it b4m just unsure how easily done it is... good luck...
Old Nov 26, 2010 | 10:36 PM
eZg's Avatar
eZg
Thanks for the response. Like you said..... Close but not quite. Worked on it today a bit. It's going to be close cause the depth of the gauges.
Old Nov 27, 2010 | 03:34 AM
lucid215's Avatar
i like this gauge setup. do you know where its available?
Old Nov 27, 2010 | 05:46 AM
herrschaft's Avatar
I will be doing something similiar, but instead of guages, I would like to place a small digital display in the flip-up lid if any will fit.
Old Nov 27, 2010 | 08:25 AM
Scootch's Avatar
lucid:
the guy custom fabricated that piece t o attach to the clock piece, and took the ash trey out n fabricated 2 guages in the space... its really not hard or if you know a good body guy who is good at fabricating...
ezg:
also to the guy ho started the thread, u know they make gauges that are not deep u can get the skinny ones which will run u more $ but u will get the out come your looking for...
Joe
Old Nov 27, 2010 | 08:37 AM
lucid215's Avatar
cool thanks fro the info
Old Nov 27, 2010 | 08:52 AM
Scootch's Avatar
here are a few site with some guage pods and some you can fabricate
if you look down on this one there are a few dif ones
http://www.streetbeatcustoms.com/int...auge-pods.html
http://www.advancespeedshop.com/epod...2b-p-6058.html
http://intensepower.com/infuatrpodg3.html
http://www.horsepowerfreaks.com/perf...ges/Gauge_Pods
Old Nov 27, 2010 | 03:45 PM
Iceman8's Avatar
https://g35driver.com/forums/forced-...auges-g35.html
Old Nov 28, 2010 | 01:44 AM
nyqueenz's Avatar
OP dont u live in MD??
Old Nov 28, 2010 | 12:43 PM
eZg's Avatar
eZg
Damn Lance, quit smoking that stuff and spinning on your head. I was up there on business when I picked up your intercooler.
I work in Mussissippi but have a daughter in Nashville. Luckily I can split my time between the two.
How is your G? I haven't seen any updates in a while
George
Old Nov 28, 2010 | 12:47 PM
eZg's Avatar
eZg
Nice thread. Were you pointing out redundancy or options? There are several diff. Solutions shown but I didn't see where anyone cut into the cubby door.
Old Nov 28, 2010 | 03:29 PM
nyqueenz's Avatar
George
lmao.... you mean break dancin on my neck..lol
I see your G is beastin George.. im glad to see your ride is hittin them high notes. I remember we were doing the builds right about the same time. I would luv to see some pics of her.
My car is about to transform again. I made 554 at the wheels on the UTEC.. im running otta fuel so now time to upgrade statge two of my project..here is the link to the update..
https://g35driver.com/forums/forced-...-part-two.html
Old Mar 17, 2011 | 11:43 PM
herrschaft's Avatar
OP, did you manage to place the gauges in the lid?
Old Mar 18, 2011 | 03:48 AM
seymore4's Avatar
m56
another place you can hide stuff is the sunglass compartment, pretty simply to run the wires and you can open/close on demand. I've got my AVC-R tucked away in there
