Vortech...belt always slippin...
Old Nov 5, 2004 | 10:25 AM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Ever since I got this system, during both tunes, the belt was loose and slipped, creating less boost. Are there any toothed belt/pulley option for this system so I'm not constantly under the car tightening the belt? Also, do you guys know how tight the belt should be? How much travel should the belt have up and down? I don't want to bend the jack shaft.
Wanna see mine?
Old Nov 5, 2004 | 01:04 PM
narkotic's Avatar
Re: Vortech...belt always slippin...
It's a constant pain in the ***, which is leading me to getting rid of it altogether.
Old Nov 5, 2004 | 01:07 PM
a.k.a. RANDYS_G
no kidding...do you know if Vortech has a toothed kit available? This HAS to be happening to all of their kits...there's nothing special about G's. It doesn't bother me enough to want to get rid of it but it does suck! BTW, if you do decide to go to that extreme, let me know...I might be interested in your pillars/gauges!
Wanna see mine?
Old Nov 5, 2004 | 01:34 PM
DFWG35's Avatar
Have you replaced your main Serpentine belt yet with a slightly shorter aftermarket belt?
Too many mods to list - 404.63hp… Complete Web Site
Old Nov 5, 2004 | 01:39 PM
iLLG35's Avatar
NY G-Squad G Race Driver
Even my UR Pulley belts slip, i cant imagine on the vortech, that must be the BIGGEST pain in the ***!!!!
Martin
2003.5 BS G35
Nismo Aero/Sport Package
0-60 5.4 - 1/4 Mile 14.16 *GTech* and on 19's!!
Old Nov 5, 2004 | 01:46 PM
a.k.a. RANDYS_G
Found the info we need:
If you want to just change your idler pulley (won't change boost at all), you can buy this item at pretty much any auto store: Dayco #89001
Or, if you want to change your belt to a 1/2 inch shorter belt, you can also find the following belt at pretty much any auto store: Goodyear #4060930
Good luck and KEEP that system!
Wanna see mine?
Old Nov 5, 2004 | 01:47 PM
a.k.a. RANDYS_G
Actually Tommy, I just did the research on a smaller idler pulley OR smaller belt...see below. Going to CalSpdWay tonight buddy! YEAH!
Wanna see mine?
Old Nov 5, 2004 | 01:50 PM
a.k.a. RANDYS_G
By the way, the idler pulley is a 1/2 inch smaller in diameter. If they are close to the same price, I'd go with the pully...easier job.
Wanna see mine?
Old Nov 5, 2004 | 04:24 PM
tig488's Avatar
i bought a Gates belt when i changed pulleys, i adjusted it after about 1 week because it stretched a little, and thats been about 2 months now, and no more slip at all, ive heard that Gates dont stretch, mine doesnt.
[image]cant get the damn thing to work[/image]
Vortech blown 03 coupe with 371 horses, sponsored by: TopSecret,Brembo,Cusco,KGMM,Volk,Injen,Alpine,JL,
-yeah right.
Old Nov 5, 2004 | 06:57 PM
booger's Avatar
Get the Gates belt . Tig488 is right . After the first adjustment I havent adjusted since .The belt is thicker and I think it actually gets tighter after it warms up . To check if its tight enough...go to the longest open length of belt , It should be tight enough to only move .4 of an inch , as Vortech suggests . Thats .4 of an inch either way , up or down , and it should be HARD to turn it 90 degree's
Couldnt afford it when young...gonna play when Im old
Old Nov 7, 2004 | 07:27 PM
a.k.a. RANDYS_G
thanks
Wanna see mine?
Old Nov 10, 2004 | 11:51 AM
narkotic's Avatar
And where can I get this belt, part # also. Thanks
Old Nov 10, 2004 | 12:13 PM
a.k.a. RANDYS_G
yeah, I wanna know too
Wanna see mine?
Old Nov 10, 2004 | 02:32 PM
justICE's Avatar
<hr></blockquote>
1/2 inch if you pull the belt with just your pinky. If you want to get real presice they do have belt tension gauges.
-JustICE
Old Nov 10, 2004 | 03:41 PM
booger's Avatar
Gates Belt # K060930 6PK2364 21mm + 2380mm O.C. Vortech suggest .4 inches of play . It should be hard to turn it to 90 degree's Bill
Couldnt afford it when young...gonna play when Im old<P ID="edit"><FONT class="small"><EM>Edited by booger on 11/10/04 01:04 PM.</EM></FONT></P>
