boost won't increase, tried two different controllers...
Old May 25, 2011 | 01:17 PM
G35Bandit's Avatar
recently got my car retuned (aps tt kit) and ditched the unichip for uprev. got it tuned at JEimport performance and we tried two different boost controllers trying to raise the boost and couldnt.
we did a boost leak test and there were none. i checked the lines running to both wastegates and they're all connectted properly but we couldn't get the turbos to boost over 7 pounds.
The weird thing is that on the drive there, i was hitting what it was previously tuned for (9.5 psi) so were not sure whats going on.
I guess I'm wondering if anyone has any ideas on whats happening. btw it's more of a curiosity thing for now because we still made 415 whp on 7 psi =D..before i was at 360whp on 9.5 psi..go figure lol
Old May 25, 2011 | 04:14 PM
Sylvan lake V35's Avatar
There is more to tuning than boost, your timing is likely more aggressive to make more power with less boost. More boost dosent always = more power.
Old May 25, 2011 | 07:06 PM
G35Bandit's Avatar
i wasn't really worried about that part of the post lol..and timing is at 75% so i guess its pretty aggressive
Old May 25, 2011 | 10:59 PM
I am sure you were not worried about that part but you seemed confused by it. If JE couldnt slove your issues looking at the car I highly doubt any internet mechanics will solve it with out seeing the car and trying a few things. If i think there are no leaks and everything is plumbed right I would pull the lines apart and re do them with new hose then you are 100% sure there are no issues there. You already tried different boost controllers did you try a manual boost "T" not much can wrong on them? Other than that waste gate or gate actuators issues would be the only thing left?
Old May 25, 2011 | 11:43 PM
G35Bandit's Avatar
haha i should just start pming you when i have a question because you seem to know your stuff. turns out..there is nothing wrong. I disconnected the boost controller (i was using a manual tee in the first place) from the wastegates and took the G out for a spin...what do ya know hit 10 psi (dangerous i know) so i connected the controller back up and spun it a couple times and the boost increased, but when i was at the shop getting dynoed, JE said that he turned it quite a bit and boost would not increase, keep in mind this is a brand new controller I picked up from their shop...so I'm not too happy because that wasted a ton of time on the dyno trying to figure out what was wrong when nothing was wrong. I'm hoping he will give me another hour of tuning for free seeing how it wasn't my fault or the car's fault boost wasn't increasing but we will see
Old May 26, 2011 | 12:59 AM
Good to hear you got it figured out, feel free to pm me if you ever have questions I will try to help if I can. I built my car myself and have had the engine and turbos swapped out pulled out or upgraded several times so I have learned a few things.
Old May 26, 2011 | 01:38 AM
nyqueenz's Avatar
+1.. more fuel and timming = more power
Old May 26, 2011 | 08:13 PM
actually less fuel....the leaner you are the more power you make to an extent, however the leaner you are the better chance of BOOM
you are right when you advance timing you add fuel to keep it "safe"
Old May 27, 2011 | 10:55 AM
djamps's Avatar
Never been a fan of manual boost controllers... good luck with your build/tune.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Hogbone
Sep 28, 2015 06:44 PM
vamarris
Sep 26, 2015 12:56 PM
ncg35guy
Sep 24, 2015 04:53 PM
