Vortech pipe wont fit?
Old Jun 11, 2011 | 10:57 PM
bokchilo's Avatar
here's the problem. I cant really get that one pipe to fit right so I will need to hear from someone who actually installed the kit before. Does that pipe go in between that thick ac line and the chassis or is it in the right place? would be nice to see some pictures if there's any. Thanks! here's my pic btw
Old Jun 11, 2011 | 11:25 PM
bigc's Avatar
Wings Nation
you're off by an inch or so...the pipe needs to be a little further back. the top of the pipe should be sandwiched between the AC line (you can bend it a bit, btw) and the shock tower.
Old Jun 12, 2011 | 12:54 AM
bokchilo's Avatar
bend the ac line at the cylinder shape part?
Old Jun 12, 2011 | 03:41 AM
bigc's Avatar
Wings Nation
just after the cylinder and above at where it comes out of the brake compartment. it will always be a snug fit, but you can massage it a bit.
Old Jun 12, 2011 | 04:04 AM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
Strafespeed intake pipe for the vortech system should speed your process up a bit =]
Old Jun 12, 2011 | 12:07 PM
Cux350z's Avatar
looks like the pipe coming off the TB has been modified/cut. It may be part of your problem.
Old Jun 12, 2011 | 12:45 PM
bigc's Avatar
Wings Nation
+1, randy's intake speeds up install as well as R & D time
OP, the offer I pm'd you still stands. let me know man.
Old Jun 12, 2011 | 12:50 PM
Really Needs a Life
+1 op.. Either way your vortech pipe from strafe will ship out tomorrow via usps
Old Jun 12, 2011 | 03:00 PM
bokchilo's Avatar
After the cylinder as in on the compressor side and not on the flexible hose side am I right?
Old Jun 12, 2011 | 03:04 PM
bokchilo's Avatar
yea my brother was having TOO much fun with the install. I'm gonna pick up a strafe vortech pipe anyways.
Old Jun 12, 2011 | 04:17 PM
Really Needs a Life
See you soon
Old Jun 12, 2011 | 08:50 PM
bigc's Avatar
Wings Nation
no, on the hose side. you can bend things just a bit for added clearance...will show you this evening when we catch up.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
