Reason Im not hitting peak boost in 1st and 2nd?
Old Sep 23, 2011 | 04:42 PM
LowNSlowG's Avatar
http://youtu.be/48EWfS800Xs
I hit 10.5 in 3rd and almost 10lbs in 2nd but 1st gear only gets to around 6lbs.
Old Sep 24, 2011 | 04:39 PM
lucid215's Avatar
probably because your not putting as much load in 1st then the other gears. thats my guess.
Old Sep 25, 2011 | 12:59 AM
LowNSlowG's Avatar
Im running a vortech supercharger
Old Sep 25, 2011 | 01:08 AM
SxExCx's Avatar
Stock gearing? If you have installed shorter gears, it might not have enough time to build enough boost.
Old Sep 25, 2011 | 03:26 AM
LowNSlowG's Avatar
New clutch and light fly wheel. 17lb fly. No gears
Old Sep 25, 2011 | 07:41 PM
binder's Avatar
supercharger is set boost per rpm (no matter what the load is) so the only want to not have the same boost for a given rpm is belt slip or a boost leak. Since a boost leak would happen in all gears it could be intermittent belt slip.
Old Sep 25, 2011 | 09:30 PM
bigc's Avatar
Wings Nation
+1, belt slip, boost leak, and/or you're not revving as high in first and second gear.
Old Sep 26, 2011 | 09:30 PM
LowNSlowG's Avatar
Think its belt slip. Just had a new belt put on few weeks ago so im sure it needs to be tightened more.
I get peak boost in 3rd so I know its not a leak.
Old Sep 27, 2011 | 12:45 AM
bigc's Avatar
Wings Nation
do you have any belt residue on your bracket (look just below the serpentine pulley) or on the bottom side of your hood?
Old Sep 28, 2011 | 08:55 PM
LowNSlowG's Avatar
I wiped my finger under the belt and around the charger and I had some black residue. Im assuming thats the belt dust, so I think its slipping.
Going to tighten it this weekend.
Old Oct 1, 2011 | 05:01 PM
binder's Avatar
yep, that's belt dust.
depending how tight it is already I usually do a 1/4 turn in of the adjusting bolt, retest, then tighten again if needed.
also, make sure it's nice and warmed up before you start tightening it. If it's super tight when it's cold it will be way too tight when it's hot. That vortech pulley can get crazy hot when you are running the car hard.
Old Oct 1, 2011 | 05:04 PM
binder's Avatar
magnetism80
Feb 1, 2019 10:00 AM
yosip1115
Sep 9, 2015 03:30 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
