GTM Turn Key Twin Turbo Kit: Good or Bad
I have a stage 1 tuner with the turn key EMS/fuel all from GTM (That combo gets you the whole turn key kit with the 3" dp's for cheaper than the turn key with dp option) It's a great kit, well designed and fit was spot on. Turn around time wasn't the best, but Sam made up for the extended wait time. I'm at 373 rwhp 358 rwtq on the turn key flash @9.5 psi. Have been for over 10K with no problems related to the turbos. Defiantly recommend highly.
The only way i would get a GTM kit is if they were installing it. They are famous for shipping kits with missing parts and taking forever to send the new parts. I havent heard much about the G35 kit myself but every other kit they have has fitment issues. like others said head over to my350z and do a search.
Still no pictures of your new projects Mike???
Actually only issue I had was the intake pipes. I got the item list and instructions for the 350z (there are no G35 specific instructions) Of course the pipes are different, so I had to just guess and check those. Also, only complaint, again just thinking of it is there is no option for external wastegates with recirculation. If you get the turn key key and have the internal wastegates you won't have to worry about this.
The kit would be for my 04 G35 Coupe. I found the kit on z1motorsports. I would be getting it from there. Is that a good idea or not? I only know of concept z performance and z1. Are there anymore sites I should check out? Also this is the cheapest kit that I can find with garret turbos. Let me know thanks.
