Catch can/Crankcase venting?
Old Sep 12, 2015 | 12:26 PM
Herbbie Hablib's Avatar
I was curious what you guys have found to be a good catch can and crankcase ventilation setups for boosted VQ's.
I read over the 20+ pages of IMO bullshit on the 350Z forums seemed like no one had a definitive setup.
After reading I was thinking of drilling out my PCV valve and adding a 300ZX brake booster check valve between the mani and the catch can. And since I am replacing the Drivers side valve cover drilling the baffling out of the rear intake vent tube hole.
Any Ideas?
Old Sep 12, 2015 | 07:41 PM
SAMzG35's Avatar
G35
Why not just run it from the passenger side valve cover (PCV) to lower intake manifold?
Old Sep 24, 2015 | 12:27 PM
eZg's Avatar
eZg
There is a great thread about this in the FI section of my 350z site.
They say any check valve at all decrease effectiveness......but plz read thread as I might have misunderstood.
gl
Old Oct 16, 2015 | 05:54 PM
b20sedan's Avatar
Drill out the passenger side PCV, throw a breather filter on it and cap the intake manifold port to the valve cover... put a breather filter on the back of the driver side valve cover too.
Old Oct 24, 2015 | 11:32 AM
ge35es's Avatar
unless you have an issue why change it from whatever the kit manufacturer recommended ?
Old Oct 24, 2015 | 08:10 PM
yosip1115's Avatar
This then drill out the drivers side valve cover port to .5" vent both through large rubber hoses to the road...
Old Oct 27, 2015 | 04:19 PM
Thanks for the help guys. I ended up drilling the drivers side VC aft breather hole out more. seems to be fine now.
Old Dec 10, 2015 | 06:17 PM
N8Deezy's Avatar
I used the hole nearest the firewall. pretty sure it's a larger hole than the ones mentioned.
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
beto4632
Sep 23, 2015 04:28 PM
underworld
Engine - Intake/Fuel
Sep 16, 2015 12:38 AM
