Vortech Running 10psi
Old Jun 4, 2005 | 09:18 PM
sickg35s's Avatar
Hey Thanks for posting my pics. We call it the sleeper because the car looks stock from the outside. Its an awesome car when we want to race because nobody knows whats inside.
Old Jun 4, 2005 | 09:40 PM
GXCLUSIV's Avatar
Stillen may use a different dyno machine, reason for your low rwhp#'s. 10psi is little high for stock VQ, maybe add more mods like ( plenum, headers, IM ) to get more HP and lower boost. Then dyno and tune Vortech again.
Old Jun 4, 2005 | 09:42 PM
sickg35s's Avatar
If you read my signature you will see that I have headers, and plenum.
Old Jun 5, 2005 | 05:12 PM
booger's Avatar
The car has a different ECU box then vortech supplied. I switched because the G3 motorsports box is a fully tunable ECU.
I would like to know what piggyback ECU you have other than the SS BOX ? But still tuned it with the R4 program ? If you used the R4 program to tune it...it's a SS BOX......NO if ands or buts about it.
I would be concerned with your EGT's with that much boost and running the stock timing . Every thing may look great...A/F ...HP... But your temps in the Cyln. maybe getting very high . To much timing and higher boost , with 10.3 to 1 compression piston will cause to high of exhaust temps . reducing the timing will help lower the temps .You have to be very careful not to go to far .
NICE LOOKING INSTALL
Old Jun 5, 2005 | 05:18 PM
booger's Avatar
OH...by the way...a 12 to 1 A/F across the board and 10psi is getting up there and I would be inclined to have it at 11.5 to1 or lower after 4000rpm
Old Jun 5, 2005 | 05:25 PM
Dsskyline's Avatar
Nice ride I met you and your son yesterday at stillen. I think your car pulled the second highest for the day. The Z with the PE kit pulled 345HP and I think 335 torque at 5psi. The stillen SC Z pulled 288hp and 259torque. Remember the dyno at churches uses a dynopack which reads 5-15 more hp because you take off the wheels. I agree your #'s are low with your mods I know that USDMV35 pulled 391HP at churches with no mods really just exhaust and some minor things. USDMV35 also has a vortech you can go to his website to check out his dyno at churches at www.usdmv35.com. I think you should contact him to see what he has done to his ride since he installed the SC himself.
Old Jun 5, 2005 | 05:28 PM
Dsskyline's Avatar
Sorry his website is www.jdmv35.com check it out. If any one wants a copy of the SC coupe vid let me know I'll send it to you since I made it.
Old Jun 5, 2005 | 06:00 PM
jaspergtr's Avatar
sickg35s - which vortech kit did you buy and what modifications to the kit did you have to have done to fit the a/t sedan? i'm looking to buy this next week, but i'm concerned about running it safely.
Old Jun 15, 2005 | 03:39 AM
codeflux's Avatar
I went to the stillen show today and pulled 342WHP on the dyno.
oh dude, i saw your G! black-looking or dark-blue, right? unfortunately i missed your dyno run, but i did drool at your car for a while.
so, you have a vortech SC on a 5AT car?... didn't realize that - vortech web site only lists it for 6MT... not street-legal in Cali, too...
let me ask you this - i know you touched on that a bit... stillen valve body upgrade didn't improve your performance when you were not F/I... in retrospect, would you prefer to wait for F/I to get stillen valve body, or would get get it before F/I too?...
Old Jun 16, 2005 | 07:06 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
I have a Auto but I also did the stillen valve body.
I agree with the low horsepower and high boost. What is the deal with that?
Sick...go back to Shawn at Churches and have him tune your car with the R4 software he has...he'll pull more power out of that beast. I dyno'ed at 388 rwhp/328lbft with him tuning my Vortech G. Tell him Randy sent you and says HI!
Old Jun 16, 2005 | 07:08 PM
a.k.a. RANDYS_G
by the way, that 388rwhp was with the stock 8psi pulley making 9psi...here's the dyno chart from Churches.
Old Jun 17, 2005 | 01:49 AM
freezeg35c's Avatar
boog, when you say too much timing you mean too much being pulled rite. Example, 8 psi 6 degrees pulled (stock split sec prog) So at 10 psi 7 or 8 degrees?
Old Jun 17, 2005 | 08:48 AM
booger's Avatar
yes..to much timing being pulled can cause high EGT's .Not enough...boom . Leave it to a good tuner
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
