Questions about the Vortech
Old Jul 21, 2005 | 09:03 PM
wanalaugh74's Avatar
Ok, I have some newbie questions.
If you get a SC, do you have to upgrade any other parts? (tranmission, pulleys, driveshaft, etc)
Anyone recommend one for a sedan?
Old Jul 21, 2005 | 09:17 PM
escobar929's Avatar
i would assume that at least the clutch will need to be upgraded
Old Jul 21, 2005 | 10:17 PM
googe's Avatar
according to everything ive read about all the FI kits, the clutch is completely adequate for an out of the box vortech, or even a slightly tuned one. maybe if you go with a smaller pulley...
its my understanding that a bolt-on vortech kit requires no other supporting mods, which is one of the reasons its an attractive option for many people.
Old Jul 22, 2005 | 11:33 AM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Originally Posted by booger
There are no reputable tuners within a couple hundred miles, so the car would have to be trailered somewhere once the kit is installed. Why? The Vortech out of the box is completely safe...in fact, too safe. You'll be fine driving it to a tuner to have a little timing pulled where it's too rich
Randy...this statement may have not been your intent . Pulling timing where the car is running rich ? Did you mean ...pull fuel ? Vortech already has a ton of timing pulled out of the box....to much ...10 degree's after 6500rpm's I think
As far as gauges...I wouldnt run a F/I set up with out a A/F and Boost gauge .
With an A/F and Boost gauge ...you can easilly see when your belt is slipping up top in the rpm range . Boost will be low and A/F will drop. If you live in an area of the US where it gets cold...boost will be higher in the winter and your A/F will lean out some .
Boog, you're right...I meant "ADVANCE" timing where rich...as far as the gauges go, I've always lived in hot areas, so I didn't consider that...
Old Jul 27, 2005 | 12:31 AM
turbomaxima's Avatar
Man with green rock in Vortech
Bringing this thread back from the dead..
I am going to do the install myself with a good friend. I am trying to compile a list of parts and part numbers for the extras to be added to the kit before installation.
Anyone have the Gates Belt part number for 3.33 pulley and for 3.12 pulley? And where to order the belt? Also, besides gauges, the NPT tap and various tools, is there anything else that I should buy before the install?
Thanks again guys.
Old Jul 27, 2005 | 10:54 AM
a.k.a. RANDYS_G
Booger could answer this question, I believe. If my memory served me correctly, the part numbers for the GATES belt ends in 935 for the 8psi pulley (means 93.5 inches) and 930 for the 9 psi pulley...Boog? Also, if I were to do it again (and eventually I will make this change) I would have upgraded my rubber hose lines that came with the system to steel braided. Especially the fuel line hose that goes to the AUX fuel pump.
Old Jul 27, 2005 | 09:31 PM
Mr_pharmD's Avatar
Would the vortech sc void the infiniti warrenty and will it pass emissions? Also, your dyno numbers, are those without upgrading your pulleys?
Old Jul 27, 2005 | 11:29 PM
Are you talking about these lines:
Old Jul 28, 2005 | 11:09 AM
a.k.a. RANDYS_G
If you are asking me, YES, adding this SC or any SC to your car will void the manufacturer warranty. Unless you had it installed by a dealership that covers it anyway. The numbers I posted were done so with the stock pully.
Old Jul 28, 2005 | 11:10 AM
a.k.a. RANDYS_G
Yes.
Old Jul 28, 2005 | 12:51 PM
socalsean's Avatar
As of now, the ONLY FI mod that will pass emissions is the Stillen SC. It will pass california's strict **** smog laws.
sean
Old Jul 29, 2005 | 09:32 PM
booger's Avatar
Randy I never had any problems at all with the fuel lines , pump , or the fmu . So couldnt say . When we did th e rebuild , I ditched it all with the return fuel System . Also the Gates belt part # ending in 935 is a 93.5 inch belt .The one you want for the 3.12 pulley is the gates ending in 930
Old Aug 1, 2005 | 12:07 PM
a.k.a. RANDYS_G
I know, but when the system first came out, some were reported busted fuel lines and so others were upgrading them...there was a comment made on how to make this system the safest possible and it was just a suggestion I made...thanks for the input.
Old Aug 1, 2005 | 06:15 PM
booger's Avatar
The only guys [ if I remember right ] having problems with it . Did self installs . The FMU has been known to have the washer get rusted and stick . But can be easily and cheaply fixed with a new one
Old Aug 8, 2005 | 11:38 AM
  #30
Brando's Avatar
Question Autosport Wiring Harness ???
Question.......
It it worth the $295.00 to buy the Wiring Harness????
Thanks
