G35 FI numbers?
Old Aug 23, 2005 | 12:57 PM
BrianlG35C's Avatar
Ohio G Club Member
1. tony 406whp 389lbtq @ 10psi w/ 4000 HARD miles on a stock block.. APS Twin Turbo kit. other mods: Water injection (very effective in keeping temperatures down) test pipes and nismo exhast. 12.9 @ 111mph but I know the car is capable of low 12's high 11's.
2. Randys_G 388whp 328lbtq (untuned on current 93 octane) Vortech SC on stock 8psi, 11,000 HARD miles with 2 road track days in 100+ temp and over 150 passes down the 1/4 mile track...other mods: Injen exhaust, Kinetix Cats...best 1/4 mile: 13.2 @ 109mph - 2.222 60ft...I know this car could do mid 12's with a new Texas tune and will def be over 400whp once that's complete...stock internals
3. Booger built motor...9 to 1 pistons . T-trim vortech , cams , return fuel system , 550 injectors...13.5psi [ for now ] 455whp and 345trq . Havent been back to the track
4. Madelinot 342rwhp, 367lbtq at 7.5psi. APS TT, 93 octane maps, completely stock (including cats and exhaust) except for the Crawford Plenum.
5. Gurgen 428rahp, 460ratq at 11.8 psi, however, it made 395rahp, 405ratq at 9 psi, so the restictive exaust and some other parts are really holding me back. PE TT, sleeved/decked block. Stock cams/valves. Test pipesm, Motordyne 1/2' spacer. Stillen exhaust. PE 510cc injectors, ecu reflash (custom developed).
6. Brianlg35C 442whp, 407lbtq @ 9 psi on stock internals. APS TT with APS Test Pipes, APS Plenum, Nismo Exhaust, UR pulley. Tuned at GRD in Naperville, IL and picked up on 8/12/05.
Old Aug 23, 2005 | 01:34 PM
WhatUpG_35's Avatar
7. WhatUpG_35 472whp, 421lbtq @ 9 psi on stock internals. APS TT with JWT Cams, Stillen Test Pipes, Injen Exhaust, Kinetix SSV IM, Koyo Radiator.
Old Aug 23, 2005 | 04:53 PM
BrianlG35C's Avatar
Ohio G Club Member
Awesome numbers WhatUp! The highest whp posted so far for FI Gs.
Old Aug 23, 2005 | 04:58 PM
g8tor20's Avatar
FGC's official flip flopper
I know right....all on stock internals... WOW
Old Aug 23, 2005 | 05:04 PM
BrianlG35C's Avatar
Ohio G Club Member
Good luck with your install, we need your numbers on here too!
Old Aug 23, 2005 | 05:06 PM
Mr_pharmD's Avatar
You guys should also mention if your AT or MT
Old Aug 23, 2005 | 05:08 PM
BrianlG35C's Avatar
Ohio G Club Member
How can we make this thread sticky?
Old Aug 23, 2005 | 05:10 PM
BrianlG35C's Avatar
Ohio G Club Member
I'll fix the ones I know...
2. Randys_G 6MT, 388whp 328lbtq (untuned on current 93 octane) Vortech SC on stock 8psi, 11,000 HARD miles with 2 road track days in 100+ temp and over 150 passes down the 1/4 mile track...other mods: Injen exhaust, Kinetix Cats...best 1/4 mile: 13.2 @ 109mph - 2.222 60ft...I know this car could do mid 12's with a new Texas tune and will def be over 400whp once that's complete...stock internals
5. Gurgen 5AT, 428rahp, 460ratq at 11.8 psi, however, it made 395rahp, 405ratq at 9 psi, so the restictive exaust and some other parts are really holding me back. PE TT, sleeved/decked block. Stock cams/valves. Test pipesm, Motordyne 1/2' spacer. Stillen exhaust. PE 510cc injectors, ecu reflash (custom developed).
6. Brianlg35C 6MT, 442whp, 407lbtq @ 9 psi on stock internals. APS TT with APS Test Pipes, APS Plenum, Nismo Exhaust, UR pulley. Tuned at GRD in Naperville, IL and picked up on 8/12/05.
Old Aug 23, 2005 | 05:40 PM
kzanard's Avatar
8. kzanard: 6MT, 379whp, 319tq, stock internals, vortech (standard pulley),crawford plenum & cats, stillen headers and exhaust.
Old Aug 23, 2005 | 07:29 PM
WhatUpG_35's Avatar
Thanks Brian! The current thought as to why my numbers were so high on stock internals is that my Kinetix SSV IM is working better with the bigger cams than say someone who is running stock cams. I am also keeping her cooler with a larger radiator and oil cooler, which helps.
Dave
Old Aug 23, 2005 | 07:32 PM
WhatUpG_35's Avatar
Adding transmission type to mine...
7. WhatUpG_35 6MT, 472whp, 421lbtq @ 9 psi on stock internals. APS TT with JWT Cams, Stillen Test Pipes, Injen Exhaust, Kinetix SSV IM, Koyo Radiator.
8. kzanard 6MT, 379whp, 319tq, stock internals, vortech (standard pulley),crawford plenum & cats, stillen headers and exhaust.
Old Aug 23, 2005 | 11:20 PM
baileyrx's Avatar
9.BAILEYRX 5AT, 350hp, 310tq, stock internals, ATI, 7psi, gutted 2ndary cats,y-pipe, 3/8in plenum spacer, no 1/4mi. yet
Old Aug 27, 2005 | 04:19 PM
Gman2004's Avatar
Dynoed with test pipes only and disconnected Greddy EVO II for my numbers below. With Greddy EVO II connected I got 430whp. I am currently looking for a new exhaust. Dyno Dynamics dyno BTW. Tuned by www.CPrace.com.
10.Gman2004 6MT, 543whp, 500tq @12 psi on a conservative tune, Greddy TT, Pauter Rods, Wiseco Pistions (81), JWT Cams, test pipes, Crawdford Plenum, RC 550 injectors, UR Pulley, TS Limited Flash, AAM Fuel Return, posting from shop no track time yet.
Old Aug 27, 2005 | 10:11 PM
g8tor20's Avatar
I finally got to join the FI club this weekend. Thanks to CP Race for the install and tune. Great job guys!!
7. WhatUpG_356MT, 472whp, 421lbtq @ 9 psi on stock internals. APS TT with JWT Cams, Stillen Test Pipes, Injen Exhaust, Kinetix SSV IM, Koyo Radiator.
11. G8tor20 5AT, 385whp & 314tq @ 10.4psi, Vortech 3.12, bone stock 2005 Coupe with Crawford H/F Cats and TS L-Spec Reflash
Old Sep 9, 2005 | 12:06 AM
  #30
marchesano's Avatar
www.g35tt.com
12. Marchesano 6MT, 409whp, 389tq @ 10 psi stock internals, APS TT. Pro 1 Test Pipes, APS Plenum, Greddy EVO II Exhaust (coming out soon), UR Pulley, 93 octane maps, no track times yet, currently untuned.
