350z PE radiator installed on my G
Old Sep 4, 2005 | 04:59 PM
Gman2004's Avatar
I just had a Power Enterprises radiator installed in my G after I discovered that my stock radiator had a hole in it. I was going install an after market radiator anyway, but I was waiting for one to hit the market that was specifically for the G. Unfortunatley I needed one now so I had the 350z PE modified to work on the G. The only fabrication that needed to be done was to extend the top mounting brackets. Unlike the Koyo, the fan blades and the shroud did not need to be cut in order to fit. IMO changing to an after market radiator with FI kits is a must, especially in Miaimi. Thanks to www.forgedinternals.com for a great price and fast shipping.
left bracket
side view
top view
right bracket
Old Sep 4, 2005 | 05:09 PM
SFLG35's Avatar
FGC President
looks good. i thought you had already gotten a koyo though? if you did what are you goin to do with that?
Old Sep 4, 2005 | 06:32 PM
Gman2004's Avatar
I sold the Koyo a few weeks ago. I didn't want to hack up the fan blades and shroud in order to make it fit. Mark from SGP recommended the PE. He says it is a better than the koyo and that a lot of people are using the koyo just cause it is cheap.
Old Sep 4, 2005 | 07:13 PM
SFLG35's Avatar
FGC President
i see
didnt know you had to cut the fan and stuff
Old Sep 5, 2005 | 10:32 PM
gq_626's Avatar
Looks like a great install GMan. Keep an eye on the temp gauge, until you confirm the cooling system was throughly purged of the air bubbles.
Old Sep 6, 2005 | 05:00 AM
Gman2004's Avatar
I went driving around Sunday night, gave the car a light beating (kept it under 4500rpms , well I redlined 1st and 2nd like twice ), and sat in heavy traffic on South Beach for about 1 hour. So far real good. The temp gauge stays pegged on the tick just below the halfway mark. BTW, getting my custom exhaust installed in about 3 hours....can't fuking wait!
Old Sep 6, 2005 | 02:01 PM
Repsol's Avatar
Where would the guage read when you had your old radiator?
Old Sep 6, 2005 | 02:10 PM
Gman2004's Avatar
that ***** was all over the place. it almost made it to the 3/4 hot mark.
Old Sep 6, 2005 | 02:58 PM
Repsol's Avatar
Wow, so it made that much of a difference? That's great.
Old Sep 6, 2005 | 03:33 PM
Gman2004's Avatar
Remember, my stock one had a hole in it so it was fuked up. The PE will definatley help with cooling as it holds twice the amount of water.
Old Sep 6, 2005 | 07:52 PM
WhatUpG_35's Avatar
Great job! It's too bad that there isn't an aftermarket radiator for our Gs yet. Just to be clear... If you do decide to buy the Koyo, it's not necessary to modify the fan blades. In my opinion, if you do, you are reducing the amount of cooling capabilities of the fan. With a good amount of filing, you can recess the fan housing enough so you don't need to reduce the size of the fan blades.
Dave
Old Sep 9, 2005 | 03:52 PM
roneski's Avatar
Devil's Advocate
Can you elaborate on what needs to be done to the mounting brackets? I'm not sure that I fully understand what you did by just looking at the pics.
Thanks.
Old Sep 9, 2005 | 05:28 PM
Gman2004's Avatar
Look at where I am pointing on the picture that shows the right side of the radiator. That metal bracket that has a 90 degree angle did not come with the radiator and was fabricated. If you look to the right of the bracket you will see a scratch. That is where the locking pin is located for the 350z. That pin was cut off, the brackets were fabricated, and the pin was welded back on the new bracket.
Old Sep 9, 2005 | 05:45 PM
roneski's Avatar
Devil's Advocate
Ahhhh... gotcha, thanks.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
NohoG35revup
Aug 22, 2015 12:13 PM
saskicker32
Aug 11, 2015 02:12 PM
joedaddy1
Jul 28, 2015 02:58 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
